Telnet Issues
vatsey.sharad
Community Member
I have two IP's Configured on my Cisco 2800. 1.1.1.1 - Loopback and 2.2.2.2 on Fast Ethernet. Both IP's are pingable across the WAN. And telnet to loopback IP is working fine. However I am unable to telnet to Fast Ethernet IP. The error message while trying to telnet to Fast Ethernet IP is: "Could not open connection to the host, on port 23: Connect failed". I tried to debug telnet on the router. The Debug output for unsuccessful telnet is as follows:
_______________________________________
Telnet194: recv SB NAWS 139 24
However for a successful telnet session, the output is:
Telnet195: 1 1 251 1
TCP195: Telnet sent WILL ECHO (1)
Telnet195: 2 2 251 3
TCP195: Telnet sent WILL SUPPRESS-GA (3)
Telnet195: 80000 80000 253 24
TCP195: Telnet sent DO TTY-TYPE (24)
Telnet195: 10000000 10000000 253 31
TCP195: Telnet sent DO WINDOW-SIZE (31)
TCP195: Telnet received DO ECHO (1)
TCP195: Telnet received DO SUPPRESS-GA (3)
TCP195: Telnet received WILL TTY-TYPE (24)
Telnet195: Sent SB 24 1
TCP195: Telnet received WILL WINDOW-SIZE (31)
Telnet195: recv SB NAWS 110 52
Telnet195: recv SB 24 0 ANSI
There are no ACL's or firewalls involved in the picture.
Richard Burts
Sharad
Perhaps it would help us to identify the problem if you would post the configuration of the router.
Rick
Rick
