Sniff a packet more than 1500 bytes on a switch
prakashj
Is it possible? If yes, could you suggest a software and the settings?
Prakash
Edison Ortiz
You need Jumbo Frame support in the switch and on the workstation running the sniffing utility.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
__
Edison.
Please rate helpful posts
Thanks Edison....
The mtu is already higher than 1500...and I am using wireshark...but still do not get any larger packet in the sniffer...
Prakash
If your devices (switches and workstation NIC) support Jumbo frames *and* they are enabled, then I don't know what else to tell you.
Perhaps asking in the wireshark forum should be the next step.
___
Edison.
