Telnet out of Cisco catalyst with ip routing enabled
laphil
I cant seem to telnet to other devices from a cisco catalyst switch whenever ip routing is enabled on the switch
Since enabling that throws the switch into L3 mode and the ip default-gateway becomes obsolete what can i do?
cadet alain
replace the ip defaut-gateway x.x.x.x by ip route 0.0.0.0 0.0.0.0 x.x.x.x
Alain
