Telnet Question
ajentilucci
Community Member
I know cisco can source an ICMP ping packet from a router and my question is can Cisco source a Telnet session IP? For example our firewall folks made rules for specific IP addresses to allow Telnet to devices behind the firewalls. Seems when I Telnet to the allowed IP on a router which happens to be the Loopback0 interface the firewall sees a physical interface on the router attempting access.
Alex Jentilucci
[email protected]
ajagadee
Yes, it is possible to source a telnet packet from a specific interface.
Example:
telnet 1.1.1.1 /source-interface loopback 0
I hope it helps.
Arul
** Please rate all helpful posts **
relsethagen
Level 4
Level 4
There is a global configuration command
ip telnet source-interface
that should allow you to do what you need.
amit-singh
Level 11
Level 11
Hi Alex,
Yes, you can source a telnet from the router itself. You have to go ahead and put the IP in the priviledge mode of the device that you want to telnet into and you will be able to get to it. Router will take any source IP from its one of the out going interface though which the detination device/subnet is reachable.
router# 10.10.10.1
password:
HTH.
-amit singh
ajentilucci
Community Member
Works!
thank you!
