11-07-2022 11:06 AM
Hello, Two users contact each other over VXLAN. I notice the user config is like the below. The user config use router to simulate user pc without gateway setting up. Is this correct? Thanks
hostname HostA ! interface GigabitEthernet2 mac-address 0000.5e00.5365 ip address 192.168.12.101 255.255.255.0 ! end
Solved! Go to Solution.
11-07-2022 12:45 PM
Right, the underlying VXLAN make both PC connect, but here you dont need GW since both PC same subnet 192.168.12.0/24.
11-07-2022 11:24 AM
Depends on the Topology or lab setup you working.
yes that is for end device, should work.
Note : this only addressed your question.
11-07-2022 11:49 AM
""The user config use router to simulate user pc without gateway setting up. Is this correct? ""
this is not all config, the router must also disable ip routing, and for your Q the answer you can do that,
the different between config GW and not config GW is type of ARP send
if you config GW then router will send ARP ask MAC of GW, and use this MAC to connect all IP out it subnet
if you not config GW then the router will send what we called proxy ARP, and use the MAC it receive to connect IP (not all) out it subnet, i.e. for each IP out it subnet the router send proxy ARP.
11-07-2022 12:35 PM
Thanks for your reply. My question is from the below diagram where there is VXLAN over the three routers. so that we think its not necessary to have gateway on each of two PCs because we just think the three router create a layer2 tunnel and two PC can think there is cable to connect the two PCs, right?
11-07-2022 12:45 PM
