Temperature of WS-X6704-10GE card?..
jackyjoy123
does anybody can tell me what is normal operating temperature of that card ?
Or if someone have that module can paste sh env temp output ?
I have few with outlet temperature around 50C which looks me too high
thanks
jackyjoy
Leo Laohoo
50C is roughly the normal operating values.
If there was anything wrong, it will be in the logs.
Scott Hodgdon
jackyjoy,
See Section 10 in the attached paper on Cat 6500 Environmental Functionality. As long as you are not crossing any temperature thresholds, which would cause log messages to be generated, then you are OK.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
@Scott Hodgdon wrote:
jackyjoy,
See Section 10 in the attached paper on Cat 6500 Environmental Functionality. As long as you are not crossing any temperature thresholds, https://creditcardsupportx.com https://creditcardsupportx.com/barnes-and-noble-barclay-mastercard
https://creditcardsupportx.com/pep-boys-credit-card which would cause log messages to be generated, then you are OK.
Cheers,
Scott Hodgdon
thanks my problem is fixed.
