Testing QOS EF packets with ping from L3 switch
hmc2500
I have an uplink configured (on a 3850 Catalyst L3 switch) with the following policy map and priority que
policy-map priority-queue
class voice
priority level 1
int gi1/0/48
service-policy output priority-queue
However when I ping I don't see any EF packets being send on the interface. Am I missing something?
ping switch2 source 10.16.10.1 tos 184 repeat 200
Sending 200, 100-byte ICMP Echos to 192.168.11.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.6.1
Success rate is 100 percent (200/200), round-trip min/avg/max = 1/21/50 ms
output:
Switch#sh policy-map int gi1/0/48
GigabitEthernet1/0/48
Service-policy output: priority-queue
queue stats for all priority classes:
Queueing
priority level 1
(total drops) 0
(bytes output) 2915622396
Class-map: voice (match-any)
0 packets
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Priority: Strict,
Priority Level: 1
Class-map: class-default (match-any)
0 packets
Match: any
(total drops) 13855256
(bytes output) 831113846637
switch#
6 Replies 6
Scott Leport
Level 7
Level 7
Does setting the decimal number to 160 work?
https://www.tucny.com/networking/dscp-tos
How about trying an extended traceroute and setting the DSCP value?
How do I set the tos value with an extended traceroute? Setting the DSCP value instead TOS with ping also did not work.
ping switch2 source gi1/0/48 tos 160
Sending 5, 100-byte ICMP Echos to 192.168.11.1, timeout is 2 seconds:
Packet sent with a source address of 10.5.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/28/40 ms
Queueing
priority level 1
(total drops) 0
(bytes output) 2923392367
0 packets
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Priority: Strict,
Priority Level: 1
0 packets
Match: any
(bytes output) 837610501010
Switch#
Joseph W. Doherty
You're pinging on/from the same switch with the policy?
If so, I recall (?) locally source traffic, although properly marked, by default, might be treated "differently" from transit traffic by the interface's egress policy.
Yes I tried pinging from the same switch with the policy. Tried pinging from a down stream switch through switch1 to switch2 too but no luck.
Pinging through the switch, from another switch, should avoid any of the possible locally sourced issues.
Over the years, I have seen bugs in Catalyst 3K switches where "interface" stats aren't correctly updated although packets are processed correctly.
I hadn't noticed before, but . . .
Queueing
priority level 1
(total drops) 0
0 packets
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Priority: Strict,
Priority Level: 1
Hmm, notice you have bytes having been sent PQ 1 by class for that PQ 1 has not packet matches?
What IOS version are you using?
Yes, I noticed the same.
One 3850 has SW image cat3k_caa-universalk9 and SW version 03.07.04E.
The other exhibiting the same problem has
SW Image CAT3K_CAA-UNIVERSALK9 and SW Version 16.3.5b
Have not checked out the newer version.
