TFTP ERROR...DROPPED because peer didnt respond
Drew
Has anyone run into an issue with solarwinds tftp server with the error message saying dropped because peer did not respond.. this is while loading Kickstart and system image on 5672 Nexus.. pings work both ways switch to client client to switch ..firewall was also turned off... it would load up to about 4Mb and then the error message would appear...
I also use a crash cart with the same procedure using solar winds and same result I wonder if solarwinds is my problem
5 Replies 5
It is sometimes better to use FTP instead of TFTP
andrecsthompson
Hello
Did you get a solution to this problem?
- Andre
fredd8605
I tried to address this by doublechecking MTU, QoS etc, but I ended up fixing this and using the Solar WInds TFTP Server successfully by configuring the timeout from 3>10 seconds  @ File>Configure>TFTP Configuration.
PaulBedford
I had this issue on Windows 10. Look at the firmware file properties and make sure that the file is not blocked (i.e. tick unblock).
rkarthik
I had the same problem. I have changed the timeout setting value from 3 to10 seconds. File>Configure>TFTP Configuration.. Issue got to be fixed for me.. Please try and confirm.
Karthik
