tftp problem
manoj.jain
Level 2
Level 2
Hii,im getting problem in to copy the switch config&Image in tftp server.The error is given below :
4003-B-Ground> (enable) copy config tftp all
IP address or name of remote host []?172.16.1.25
Name of file to copy to [4003-B-Ground.cfg]?
Upload configuration to tftp:4003-B-Ground.cfg
, (y/n) [n]? y
No response from host.
TFTP connection fail(-1).
file tftp:4003-B-Ground.cfg cannot be opened for write (TFTP write error)
Cannot write buffer to file
Cannot copy from config: to tftp:4003-B-Ground.cfg
I m using solarwinds and i check all the security settings its correct.plz guide me to solve this problem
Thanx
6 Replies 6
sourabhagarwal
Level 9
Level 9
Hi Manoj,
few things needs to be checked.
can u verify IP connectivity between the switch and tftp server. ping 172.16.1.25 from
4003-B-Ground switch and see if it succeds.
check if TFTP server is running.
check if solarwinds tftp is set to send and receive files both.
check if you have set the paath in tftp where the config files from the switch will get saved.
rate if it helps ... try it and let me know if you have any questions....
Hii
friend im doing telnet from 172.16.1.25, so there is no issue of connectivity and also i set both the permssion(send& recieve),but even then im getting this error.
and my path is c:\tftp-root
Thanx
amit-singh
Level 11
Level 11
Try another TFTP server. Check the link below and its a recommended one by Cisco.
http://tftpd32.jounin.net/
HTH,
-amit singh
It seems that the directory that you are using on the TFTP server for receiving files has not been given write permissions.
Hii amit ,,
Thanx for ur help..with this i m able to copy the file in tftp server.
Thanx
Amit
If u see my earlier post regarding c-8540 CSR-RP, can u tell me something about that or guide me to solve that problem also.
Thanx
Manoj Jain
