throughput problem
hossinymasoud
Community Member
Two servers connect to the Cisco nexus 6000 switch with a 10g fiber port. However, we have a problem: the throughput on this switch is not more than 100 megabytes, but when we connect the servers directly, they also have up to 9 gigabytes.
Thanks.
Problem solved.
I changed the fiber from single-mode to multi-mode, and everything is ok.
balaji.bandi
need some clarification here :
1. are you testing from server to server (both are connected to same switch) ?
2. Server to server (with out switch) you getting 9gigabits ?
what servers ?
BB
yes. there connected to the same switch.
yes.
what servers ?
hope g9 dl380,with fiber SFP
Can you share both the ports connected to servers
show run interface ethernet x/x
show interface ethernet x/x
show vers
BB
Thanks.
Problem solved.
