Topology question--> Cable or Switch?
Vasconcelos
Hi, everyone,
So, on the topology below, can someone tell me how do I know if the line represents a Cable (Bus Topology) or a Switch?
Abheesh Kumar
It should be a single cable that connects all the nodes. If you connect it via a switch/hub called as star topology.
Abheesh
Yes, I understand. However, how can I know, by looking at the topology, if it's a Cable or a Switch?
As per the topology its a bus.
Now a days i dont think so still using bus topology. Everything should be connected via a hub or a switch. Below link will help you to understand more about topology.
https://www.studytonight.com/computer-networks/network-topology-types
Abheesh
