%TRANSCEIVER-3-NOT_COMPATIBLE: R0/0: iomd: Detected for transceiver module in HundredGigabitEthernet
Hi Guys
i've met unpleasant stuff with below inventory:
Switch#sho inve | i 9500|QSFP
NAME: "Chassis", DESCR: "Cisco Catalyst 9500 Series Chassis"
PID: C9500-48Y4C , VID: V02 , SN: XXXXXXX
PID: QSFP-40/100-SRBD , VID: V02 , SN: FTF2428N64C
PID: QSFP-40/100-SRBD , VID: V02 , SN: FTF2428N73G
QSFPs get disabled
*Jan 11 13:14:20.550: %TRANSCEIVER-3-NOT_COMPATIBLE: R0/0: iomd: Detected for transceiver module in HundredGigabitEthernet1/0/49, module disabled
*Jan 11 13:14:20.555: %TRANSCEIVER-3-NOT_COMPATIBLE: R0/0: iomd: Detected for transceiver module in HundredGigabitEthernet1/0/50, module disabled
Switch#sho interfa status | i Hu
Hu1/0/49 err-disabled routed full 1000 unknown
Hu1/0/50 err-disabled routed full 1000 unknown
service unsupported-transceiver doesnt help :0(
switch is running 16.09.05
any help please?
--> switch is running 16.09.05
I checked the compatibility matrix (linked below), it says that the QSFP-40/100-SRBD requires IOS XE 16.12.1 at a minimum, maybe that is the problem.
https://tmgmatrix.cisco.com/?si=C9500-48Y4C
8 Replies 8
balaji.bandi
Try  -
no errdisable detect cause gbic-invalid
Also post show interface hun 1/0/49 and 1/0/50
what is the other side connected ?
check this thread also may help you :
https://community.cisco.com/t5/switching/issue-with-9500-32c-and-using-cvr-qsfp-sfp10g/td-p/3837856
BB
hi Balaji
on the opposite side is the same HW/SW with exactly the same problem. also i have all errdisable cause detect * disabled:
no errdisable detect cause sfp-config-mismatch
Switch#sho int hu1/0/49
HundredGigE1/0/49 is down, line protocol is down (err-disabled)
Hardware is Hundred Gigabit Ethernet, address is XXXX.YYYY.ZZZZ (bia XXXX.YYYY.ZZZZ)
MTU 1500 bytes, BW 100000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is on, output flow-control is off
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:01:17
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
balaji.bandi
Not sure this solve the issue.
I follow below steps :
1. remove the SFP and default the port
2. if the port is 10GB SFP - make the port with speed 10GB config
3. insert the SFP, see if that works. - this should do both the sides.
Still issue - check the compatability matrix - this is more of hardware issue - so repalce with correct supported vendor SFP
Another important thing is last 4 ports of uplink is 40/100GB only - are you trying 10GB SFP may not work as per i know.
you can try any other ports 1-48 and see if that works ?
BB
Hi Balaji,
as i noticed we r using below QSFPs (which r obviously only 40/100Gbps - as taken from "show inventory"):
& we r using them exclusively in the Hu1/0/49-52 ports (which r 40/100Gbps compatible only). So there shouldnt be any mismatch between QSFPs & slots they r in.
i'm frustrated...
what vendor is this ?  see the speed this worries me.
BB
Contacted Cisco TAC. They said 100G QSFPs r supported on 16.12.1 minimum. will do n upgrade tomorrow & keep community posted.
Sure that is the version we are running 16.12.4 is my current Cat 9500 work great and good luck.
BB
