Transceiver port of Catalyst 2960
samgbuyi
I am presently using 1GB transceiver on my Catalyst 2960, please can i use 10GB transceiver on Catalyst 2960 switch?
Please kindly advice on which way to go.
balaji.bandi
its been Long time worked on 2960, personally I do not believe as i remember it supports 10GB uplink port
Data information ( since we do no exact model you have- please refer below guides:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.html
Also, check what SFP you looking to install - it will also guide you compatibility matrix of your device model listed here or not.
https://tmgmatrix.cisco.com/
BB
Reza Sharifi
2960 does not support 10Gig optic, however 2960-X does.
Please post the result of sh ver command
Hi All,
Cisco 2960X has 2 variants in uplinks 1G and 10G. If your switch is having 4 Uplink ports then it is 1G and if it is having 2 Uplink ports then it is 10G. Below are the part number examples.
WS-C2960X-48FPS-L --- this is 48 Port POE with 4X1G uplinks
WS-C2960X-48FPD-L ------ this is 48 Port POE with 2 X 10G uplinks.
Mark the post if it is clear for you
