Trouble with a C9300-48T-e switch
stuartmair
Need to reset to factory default-how is that done in the C9300-48T-E switch.
szeya
there is two options:
First option :
Step 1 Press and hold the Mode button. The switch LEDs begin blinking after about 3 seconds.
Step 2 Continue holding down the Mode button. The LEDs stop blinking after 7 more seconds, and then the switch restarts.
Second option :
C9300#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm] yes
szeya
First option :
Second option :
C9300#write erase
