Wrong IOS SM-X-ES3-24, stuck in a boot loop
lancerobinson
Well, I loaded the wrong IOS on a 3650-X (SM-X-ES3-24) module. I loaded the IOS for a SM-ES3-24... Now I'm stuck in a boot loop and can not break the boot with CTRL+BREAK... Does the following over and over... Any ideas?
Using driver version 3 for media type 2
Base ethernet MAC Address: bc:f1:f2:38:61:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 12 files, 1 directories
mifs[2]: Total bytes     :    2097152
mifs[2]: Bytes used      :     892928
mifs[2]: Bytes available :    1204224
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 1 files, 1 directories
mifs[3]: Total bytes     :    4194304
mifs[3]: Bytes used      :     217088
mifs[3]: Bytes available :    3977216
mifs[3]: mifs fsck took 1 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     524288
mifs[4]: Bytes used      :      49152
mifs[4]: Bytes available :     475136
mifs[4]: mifs fsck took 1 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     524288
mifs[5]: Bytes used      :      49152
mifs[5]: Bytes available :     475136
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes     :   30408704
mifs[6]: Bytes used      :   20328448
mifs[6]: Bytes available :   10080256
mifs[6]: mifs fsck took 8 seconds.
*Jun 27 15:57:47.329: %SPA_OIR-3-EVENT_TIMEOUT: subslot 1/0: Timeout waiting for SPA OIR event
-Traceback= 1#7817c0a29514ddaa79657a1504cf62e9  :7F56B5DC9000+B4707F3 :7F56B5DC9000+B448C30 :7F56B5DC9000+92C84D7 :7F56B5DC9000+B445E92 :7F56B5DC9000+A807999
*Jun 27 15:57:52.332: %SPA_OIR-3-RECOVERY_RELOAD: subslot 1/0: Attempting recovery by reloading SPA
*Jun 27 15:57:52.334: %SPA_OIR-6-OFFLINECARD: SPA (SM-X-ES3-24-P) offline in subslot 1/0
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes     :   88735744
mifs[7]: Bytes used      :   38326272
mifs[7]: Bytes available :   50409472
mifs[7]: mifs fsck took 24 seconds.
...done Initializing Flash.
done.
Verifying image ucode0:usbdos.dl....
Image passed digital signature verification
Verifying bootloader image........
BootLoader self verification passed
Loading "flash:/c3560e-universalk9-mz.122-58.SE2.bin"...Verifying image flash:/c3560e-universalk9-mz.122-58.SE2.bin..................................................................................................................................................................................................................................................................................
WARNING: Unable to determine image authentication.Image is either unsigned or is signed but corrupted.
File "flash:/c3560e-universalk9-mz.122-58.SE2.bin" uncompressed and installed, entry point: 0x3000
executing...
Error: hardware not supported by firmware.
       Try loading newer software instead.
       System Resetting...
5 Replies 5
Reza Sharifi
Can you hold down the mode button and see if you can break into it that way?
I wish I could, SM modules do not have mode buttons.
Figured it out, from the router use the following command.
 hw-module subslot 1/0 error-recovery password_reset
I'm having the same issue however I get an invalid input when trying to enter the command.
#hw-module subslot 1/0 error-recovery password_reset
% Invalid input detected at '^' marker.
Found solution,
service-module interface slot/port password-reset
