Troubleshooting commands on 3560G or 3750G? Strange issues.
ttrevino1
I'm seeing some odd behavior on one of my 3750 switches and was wondering what commands I can use to troubleshoot with? Or use for diagnostic review? The two issues I'm seeing are I use Packettrap switchport mappper and for some reason on this switch, it's not working. I get a "No SNMP response when checking sysObjectId (1.3.6.1.2.1.1.2.0). Check IP and community string" error. Basically it's saying it can't read the IP or community string, which I've confirmed are both correct and the community string matches the other switches, which do work with this software.
The other issue I had last night, (which might be a Desktop Authority or other 3rd party software issue) is I configured a users switchport for a different vlan for some testing we're doing, and I could confirm it would move to the new vlan, but within a minute, it would be back in the original vlan. I moved this port multiple times, and even moved the user to a differernt switchport, made the same change, and it moved back to the original vlan exactly the same!
I plan to reboot the switch stack as they've been up over 2 years and 30 weeks, but I'd like to see if I can figure out what's going on (or there are any reset or clear commands I can use to resolve these issues) before I reboot the switch and lose any diagnostic information.
Thanks in advance for any help, Tony
glen.grant
    If the port is switching vlans it sounds like it is setup for 802.1X  authentication.
I don't believe the switch is set up for 802.1x, but how can I confirm? This user is also now on WIndows 7, if this makes any difference? I wouldn't think it would, however, when we were checking her NIC settings, it kept asking for an adminstrator password. Might be a desktop authority thing, but thought it was odd...
Port config:
interface GigabitEthernet1/0/3
switchport access vlan xxx
spanning-tree portfast
Switch config:
version 12.2
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service sequence-numbers
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login telnet group tacacs+ local
aaa authentication login ssh group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa session-id common
switch 1 provision ws-c3750g-48ts
switch 2 provision ws-c3750g-48ts
switch 3 provision ws-c3750g-48ts
ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree portfast default
ip classless
ip http server
ip http authentication aaa
logging trap debugging
snmp-server engineID local 000000090200001B0D6803C0
snmp-server enable traps snmp authentication linkdown linkup coldstart
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps vtp
snmp-server enable traps mac-notification
snmp-server enable traps config
snmp-server enable traps hsrp
snmp-server enable traps vlan-membership
radius-server source-ports
control-plane
mac-address-table notification interval 0
mac-address-table notificationip classless
sho dot1x
Sysauthcontrol             Disabled
Dot1x Protocol Version            2
Critical Recovery Delay         100
Critical EAPOL             Disabled
