Troubleshooting DHCP helper on 2960-X
Garegin88
I have a DHCP helper on a CAT 2960-X.
Have set up a helper address as my DHCP server, which is a Mikrotik
Vlan1 is up, line protocol is up
Internet address is [10.5.1.5/24]
Broadcast address is [255.255.255.255](https://255.255.255.255)
Vlan100 is up, line protocol is up
Internet address is [10.5.2.1/24]
Address determined by configuration file
MTU is 1500 bytes
Helper address is [10.5.1.90]
The problem is that is I don't know if the helper is receiving DHCP requests from VLAN100 to forward them to [10.5.1.90]
The Mikrotik is set up to only give out addresses on the [10.5.2.1/24] subnet, but is connected to VLAN 1.
The switch has [10.5.1.1] (firewall) (show ip default-gateway) as the default gateway, but hosts on VLAN 100 (when configured with a static address) can ping [10.5.1.1] but not [10.5.1.90].
update: I just checked and I can’t ping hosts on VLAN 1 from VLAN 100, except for the VLAN 1’s interface of 10.5.1.5 and 10.5.1.1
But can ping hosts on VLAN 100 from VLAN 1.
It seems like a routing issue. Probably because the gateway for the different subnets are their respective IP addresses on one firewall. But the gateway for 10.5.2.0/24 is the switch SVI on VLAN 100.
I can however go to internet from VLAN 100. Somehow the SVI (10.5.2.1) is routing the traffic successfully to the internet.
balaji.bandi
If you looking switch to do routing, then you need to enable -  ip routing. to guide better post complete show run to understand what is configured as per below output :
show run
show ip interface brief
show ip route
BB
Garegin88
Ok. I figured out why I can't ping between the MT and hosts on VLAN 100 (and vice versa). The MT didn't have a default gateway. Set up the default gateway as 10.5.1.5 (firewall) and I can ping back and forth.
The issue is still that I don't know if the helper is even working, as in forwarding requests to the MT.
Here is the info you asked for.
show run
Building configuration...
Current configuration : 34331 bytes
! Last configuration change at 22:35:16 CET+1 Mon Oct 18 2021 by doco
! NVRAM config last updated at 21:18:17 CET+1 Mon Oct 18 2021 by doco
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
hostname nsdocony0101
boot-start-marker
boot-end-marker
logging buffered 1048576
logging rate-limit console 10
no logging console
enable secret 5 $1$wOg3$X3kxADSPbtZV7Px4QFIaW1
username ntsadmin privilege 15 secret 5 $1$6bQL$aZf6y7jA7vXFWCf9D3Q3K/
username admin privilege 15 secret 5 $1$xVi7$jlbE7jAIFmB2ipG9yufcl/
username doco privilege 15 password 7 020810485F020022431C594B5553
aaa new-model
aaa authentication login con-auth local-case
aaa authentication login vty-auth local-case
aaa authentication login http-auth local-case
aaa authorization console
aaa authorization exec con-author local
aaa authorization exec vty-author local
aaa authorization exec http-author local
aaa session-id common
clock timezone CET 1 0
clock summer-time CET+1 recurring last Sun Mar 2:00 last Sun Oct 3:00
switch 1 provision ws-c2960x-48fpd-l
switch 2 provision ws-c2960x-48fpd-l
ip routing
ip dhcp excluded-address 10.5.1.1 10.5.1.100
ip dhcp excluded-address 10.5.1.200 10.5.1.255
ip dhcp pool VLAN1-TEMP
network 10.5.1.0 255.255.255.0
default-router 10.5.1.1
dns-server 1.1.1.1 1.0.0.1
no ip domain-lookup
ip domain-name doco.com
login block-for 30 attempts 5 within 90
login quiet-mode access-class emergency-access
udld aggressive
crypto pki trustpoint TP-self-signed-3036951680
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3036951680
revocation-check none
rsakeypair TP-self-signed-3036951680
crypto pki certificate chain TP-self-signed-3036951680
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33303336 39353136 3830301E 170D3138 30353038 31373434
33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30333639
35313638 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C32D 7703DB58 29CE5CC7 175D7379 0D7E9CFE B7EBFB6F CA52C7A6 295F4E09
7EE3F272 D96013D8 5AE8B823 EA1E44EA 7D02B121 B6E9E241 A2866C30 0D1A050D
121DBBCF 6090DC7E 519E2EBB 906F1A55 14D9D17D C743F94E BA7C5488 F04A8607
7AB3D4DF 157A9D3F B0B29271 1EF2B93F C5695720 0EC80E75 D90960D4 DA1084DC
66510203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14CD529F F1A0758F 2B7DC348 1090A3C3 9BA34536 37301D06
03551D0E 04160414 CD529FF1 A0758F2B 7DC34810 90A3C39B A3453637 300D0609
2A864886 F70D0101 05050003 818100A4 9B83A6E3 B6480DF0 8335CB1E D1E46022
70EB1FF3 A2976DB4 6C2DBEF3 3E463FF3 2AD2EE17 1F034242 341E513A A0C6BA59
6C093D27 0F3131E7 B1D92368 1B5B6760 A5E4DA5C 281B1724 DC16C678 47896739
EA68E48A B2D78402 865CE629 8C9F7409 682C34B7 BDAB5C7B 336B66D0 17B42477
C8B6D5E7 9792B882 8F537267 2B2D29
quit
archive
path flash:/configbackup/nsdocony0101
maximum 14
write-memory
time-period 10080
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
spanning-tree vlan 1-4094 priority 4096
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
errdisable recovery cause psp
errdisable recovery interval 600
vlan internal allocation policy ascending
lldp run
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
description UPLINK ASA VLAN1
switchport mode access
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
description UPLINK ASA VLAN 12 - GUEST
switchport access vlan 12
interface GigabitEthernet1/0/3
description UPLINK WLC Port 1
switchport trunk allowed vlan 1,12,310,330
switchport mode trunk
spanning-tree portfast trunk
interface GigabitEthernet1/0/4
description SERVER
interface GigabitEthernet1/0/5
description ACCESS POINT
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
description ShoreTel Voice Switch
switchport access vlan 100
interface GigabitEthernet1/0/10
description UPLINK ASA TRUNK
interface GigabitEthernet1/0/11
description CLIENT
switchport voice vlan 100
no logging event link-status
no snmp trap link-status
storm-control broadcast level 1.00
storm-control multicast level 1.00
storm-control action trap
interface GigabitEthernet1/0/12
description CLIENT
switchport access vlan 200
interface GigabitEthernet1/0/13
description CLIENT
interface GigabitEthernet1/0/14
description CLIENT
interface GigabitEthernet1/0/15
description CLIENT
interface GigabitEthernet1/0/16
description CLIENT
interface GigabitEthernet1/0/17
description CLIENT
interface GigabitEthernet1/0/18
description CLIENT
interface GigabitEthernet1/0/19
description CLIENT
interface GigabitEthernet1/0/20
description CLIENT
interface GigabitEthernet1/0/21
description CLIENT
interface GigabitEthernet1/0/22
description CLIENT
interface GigabitEthernet1/0/23
description CLIENT
interface GigabitEthernet1/0/24
description CLIENT
interface GigabitEthernet1/0/25
description CLIENT
interface GigabitEthernet1/0/26
description CLIENT
interface GigabitEthernet1/0/27
description CLIENT
switchport access vlan 280
interface GigabitEthernet1/0/28
description CLIENT
interface GigabitEthernet1/0/29
description CLIENT
interface GigabitEthernet1/0/30
description CLIENT
interface GigabitEthernet1/0/31
description CLIENT
interface GigabitEthernet1/0/32
description CLIENT
interface GigabitEthernet1/0/33
description CLIENT
interface GigabitEthernet1/0/34
description CLIENT
interface GigabitEthernet1/0/35
description CLIENT
interface GigabitEthernet1/0/36
description CLIENT
interface GigabitEthernet1/0/37
description CLIENT
interface GigabitEthernet1/0/38
description CLIENT
interface GigabitEthernet1/0/39
description CLIENT
interface GigabitEthernet1/0/40
description CLIENT
interface GigabitEthernet1/0/41
description CLIENT
interface GigabitEthernet1/0/42
description CLIENT
interface GigabitEthernet1/0/43
description CLIENT
interface GigabitEthernet1/0/44
description CLIENT
interface GigabitEthernet1/0/45
description CLIENT
interface GigabitEthernet1/0/46
description CLIENT
interface GigabitEthernet1/0/47
description CLIENT
interface GigabitEthernet1/0/48
description CLIENT
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface TenGigabitEthernet1/0/1
description UPLINK SWITCH
spanning-tree bpduguard disable
interface TenGigabitEthernet1/0/2
interface GigabitEthernet2/0/1
description UPLINK - ASA VLAN1 _ RESERVED
interface GigabitEthernet2/0/2
description UPLINK ASA VLAN 12 - GUEST _ RESERVED
interface GigabitEthernet2/0/3
description UPLINK WLC Port 2 _ RESERVED
interface GigabitEthernet2/0/4
description SERVER
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
description CLIENT
interface GigabitEthernet2/0/10
description CLIENT
interface GigabitEthernet2/0/11
description CLIENT
interface GigabitEthernet2/0/12
description CLIENT
interface GigabitEthernet2/0/13
description CLIENT
interface GigabitEthernet2/0/14
description CLIENT
interface GigabitEthernet2/0/15
description CLIENT
interface GigabitEthernet2/0/16
description CLIENT
interface GigabitEthernet2/0/17
description CLIENT
interface GigabitEthernet2/0/18
description CLIENT
interface GigabitEthernet2/0/19
description CLIENT
interface GigabitEthernet2/0/20
description CLIENT
interface GigabitEthernet2/0/21
description CLIENT
interface GigabitEthernet2/0/22
description CLIENT
interface GigabitEthernet2/0/23
description CLIENT
interface GigabitEthernet2/0/24
description CLIENT
interface GigabitEthernet2/0/25
description CLIENT
interface GigabitEthernet2/0/26
description CLIENT
interface GigabitEthernet2/0/27
description CLIENT
interface GigabitEthernet2/0/28
description CLIENT
interface GigabitEthernet2/0/29
description CLIENT
interface GigabitEthernet2/0/30
description CLIENT
interface GigabitEthernet2/0/31
description CLIENT
interface GigabitEthernet2/0/32
description CLIENT
interface GigabitEthernet2/0/33
description CLIENT
interface GigabitEthernet2/0/34
description CLIENT
interface GigabitEthernet2/0/35
description CLIENT
interface GigabitEthernet2/0/36
description CLIENT
interface GigabitEthernet2/0/37
description CLIENT
interface GigabitEthernet2/0/38
description CLIENT
interface GigabitEthernet2/0/39
description CLIENT
interface GigabitEthernet2/0/40
description CLIENT
interface GigabitEthernet2/0/41
description CLIENT
interface GigabitEthernet2/0/42
description CLIENT
interface GigabitEthernet2/0/43
description CLIENT
interface GigabitEthernet2/0/44
description CLIENT
interface GigabitEthernet2/0/45
description CLIENT
interface GigabitEthernet2/0/46
description CLIENT
interface GigabitEthernet2/0/47
description CLIENT
interface GigabitEthernet2/0/48
description CLIENT
interface GigabitEthernet2/0/49
interface GigabitEthernet2/0/50
interface TenGigabitEthernet2/0/1
interface TenGigabitEthernet2/0/2
interface Vlan1
ip address 10.5.1.5 255.255.255.0
interface Vlan100
ip address 10.5.2.1 255.255.255.0
ip helper-address 10.5.1.90
ip default-gateway 10.5.1.1
no ip http server
ip http authentication aaa login-authentication http-auth
ip http authentication aaa exec-authorization http-author
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.5.1.1
ip ssh version 2
ip access-list standard emergency-access
permit 10.0.8.0 0.0.1.255
ip access-list standard snmp-access
permit 10.0.9.46
ip access-list standard vty-access
permit any
snmp-server community public RO snmp-access
snmp-server enable traps transceiver all
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps storm-control trap-rate 10
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps errdisable
no vstack
line con 0
exec-timeout 15 0
logging synchronous
login authentication con-auth
line vty 0 4
access-class vty-access in
exec-timeout 15 0
logging synchronous
login authentication vty-auth
line vty 5 15
exec-timeout 15 0
logging synchronous
ntp server 10.0.9.7
end
show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 10.5.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.5.1.1
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.5.1.0/24 is directly connected, Vlan1
L 10.5.1.5/32 is directly connected, Vlan1
C 10.5.2.0/24 is directly connected, Vlan100
L 10.5.2.1/32 is directly connected, Vlan100
Vlan1 10.5.1.5 YES TFTP up up
Vlan100 10.5.2.1 YES TFTP up up
FastEthernet0 unassigned YES TFTP administratively down down
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset down down
GigabitEthernet1/0/3 unassigned YES unset up up
GigabitEthernet1/0/4 unassigned YES unset down down
GigabitEthernet1/0/5 unassigned YES unset down down
GigabitEthernet1/0/6 unassigned YES unset down down
GigabitEthernet1/0/7 unassigned YES unset down down
GigabitEthernet1/0/8 unassigned YES unset down down
GigabitEthernet1/0/9 unassigned YES unset up up
GigabitEthernet1/0/10 unassigned YES unset up up
GigabitEthernet1/0/11 unassigned YES unset down down
GigabitEthernet1/0/12 unassigned YES unset up up
GigabitEthernet1/0/13 unassigned YES unset up up
GigabitEthernet1/0/14 unassigned YES unset up up
GigabitEthernet1/0/15 unassigned YES unset up up
GigabitEthernet1/0/16 unassigned YES unset up up
GigabitEthernet1/0/17 unassigned YES unset up up
GigabitEthernet1/0/18 unassigned YES unset down down
GigabitEthernet1/0/19 unassigned YES unset up up
GigabitEthernet1/0/20 unassigned YES unset down down
GigabitEthernet1/0/21 unassigned YES unset down down
GigabitEthernet1/0/22 unassigned YES unset down down
GigabitEthernet1/0/23 unassigned YES unset down down
GigabitEthernet1/0/24 unassigned YES unset down down
GigabitEthernet1/0/25 unassigned YES unset down down
GigabitEthernet1/0/26 unassigned YES unset down down
GigabitEthernet1/0/27 unassigned YES unset up up
GigabitEthernet1/0/28 unassigned YES unset down down
GigabitEthernet1/0/29 unassigned YES unset up up
GigabitEthernet1/0/30 unassigned YES unset down down
GigabitEthernet1/0/31 unassigned YES unset down down
GigabitEthernet1/0/32 unassigned YES unset down down
GigabitEthernet1/0/33 unassigned YES unset down down
GigabitEthernet1/0/34 unassigned YES unset down down
GigabitEthernet1/0/35 unassigned YES unset up up
GigabitEthernet1/0/36 unassigned YES unset up up
GigabitEthernet1/0/37 unassigned YES unset down down
GigabitEthernet1/0/38 unassigned YES unset down down
GigabitEthernet1/0/39 unassigned YES unset down down
GigabitEthernet1/0/40 unassigned YES unset down down
GigabitEthernet1/0/41 unassigned YES unset up up
GigabitEthernet1/0/42 unassigned YES unset down down
GigabitEthernet1/0/43 unassigned YES unset up up
GigabitEthernet1/0/44 unassigned YES unset up up
GigabitEthernet1/0/45 unassigned YES unset down down
GigabitEthernet1/0/46 unassigned YES unset down down
GigabitEthernet1/0/47 unassigned YES unset down down
GigabitEthernet1/0/48 unassigned YES unset down down
GigabitEthernet1/0/49 unassigned YES unset down down
GigabitEthernet1/0/50 unassigned YES unset down down
Te1/0/1 unassigned YES unset down down
Te1/0/2 unassigned YES unset down down
GigabitEthernet2/0/1 unassigned YES unset down down
GigabitEthernet2/0/2 unassigned YES unset down down
GigabitEthernet2/0/3 unassigned YES unset up up
GigabitEthernet2/0/4 unassigned YES unset down down
GigabitEthernet2/0/5 unassigned YES unset up up
GigabitEthernet2/0/6 unassigned YES unset down down
GigabitEthernet2/0/7 unassigned YES unset down down
GigabitEthernet2/0/8 unassigned YES unset down down
GigabitEthernet2/0/9 unassigned YES unset down down
GigabitEthernet2/0/10 unassigned YES unset down down
GigabitEthernet2/0/11 unassigned YES unset down down
GigabitEthernet2/0/12 unassigned YES unset down down
GigabitEthernet2/0/13 unassigned YES unset down down
GigabitEthernet2/0/14 unassigned YES unset down down
GigabitEthernet2/0/15 unassigned YES unset down down
GigabitEthernet2/0/16 unassigned YES unset down down
GigabitEthernet2/0/17 unassigned YES unset down down
GigabitEthernet2/0/18 unassigned YES unset down down
GigabitEthernet2/0/19 unassigned YES unset down down
GigabitEthernet2/0/20 unassigned YES unset down down
GigabitEthernet2/0/21 unassigned YES unset down down
GigabitEthernet2/0/22 unassigned YES unset down down
GigabitEthernet2/0/23 unassigned YES unset down down
GigabitEthernet2/0/24 unassigned YES unset down down
GigabitEthernet2/0/25 unassigned YES unset down down
GigabitEthernet2/0/26 unassigned YES unset down down
GigabitEthernet2/0/27 unassigned YES unset down down
GigabitEthernet2/0/28 unassigned YES unset down down
GigabitEthernet2/0/29 unassigned YES unset up up
GigabitEthernet2/0/30 unassigned YES unset down down
GigabitEthernet2/0/31 unassigned YES unset down down
GigabitEthernet2/0/32 unassigned YES unset up up
GigabitEthernet2/0/33 unassigned YES unset down down
GigabitEthernet2/0/34 unassigned YES unset down down
GigabitEthernet2/0/35 unassigned YES unset down down
GigabitEthernet2/0/36 unassigned YES unset down down
GigabitEthernet2/0/37 unassigned YES unset down down
GigabitEthernet2/0/38 unassigned YES unset down down
GigabitEthernet2/0/39 unassigned YES unset up up
GigabitEthernet2/0/40 unassigned YES unset up up
GigabitEthernet2/0/41 unassigned YES unset down down
GigabitEthernet2/0/42 unassigned YES unset down down
GigabitEthernet2/0/43 unassigned YES unset down down
GigabitEthernet2/0/44 unassigned YES unset down down
GigabitEthernet2/0/45 unassigned YES unset down down
GigabitEthernet2/0/46 unassigned YES unset down down
GigabitEthernet2/0/47 unassigned YES unset up up
GigabitEthernet2/0/48 unassigned YES unset down down
GigabitEthernet2/0/49 unassigned YES unset down down
GigabitEthernet2/0/50 unassigned YES unset down down
Te2/0/1 unassigned YES unset up up
Te2/0/2 unassigned YES unset up up
