Dot1x Issue
Networker0
Hello Team,
We are configuring dot1x on ASR1001-x, the configuration is detailed below:
Router(config)# dot1x system-auth-control
Router(config)# aaa new-model
Router(config)# aaa authentication dot1x default group radius
Router(config)# interface GigabitEthernet0/0/2
Router(config-if)# dot1x pae authenticator
Router(config-if)# authentication port-control auto
Even after enabling 802.1x on the port, the ASR1001-x is not detecting the 802.1x client.
Any idea?
balaji.bandi
what is the version of the IOS XE ? do you have the radius server group configured ? enable-debug and check(post the debug Logs)
look at the example :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/macsec/configuration/xe-16-6/macsec-xe-16-6-book/macsec-xe-16-6-book_chapter_010.html#id_32878
BB
hemmerling
Level 3
Level 3
Setup the server group like this:
radius server RADIUS_SERVER1
 address ipv4 192.168.1.123 auth-port 1812 acct-port 1813
 key 0 myspecialpassword
might also want to include these on your interface as well:
 authentication event fail action next-method
 authentication event server alive action reinitialize
 authentication host-mode multi-domain
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication violation restrict
 mab
So a complete version would be:
aaa new-model
 mab
assuming you will eventually want to add MAB and phones to the mix.
EDIT:
Unless it might be the bizarre "password encryption aes + type 6 RADIUS passwords + FIPS" bug I noticed 18 months ago, where if you have all those elements together that RADIUS is just ignored. Weirdest part is that you can have all of it on and with type 7 passwords, but if you remove the server group and add it back, they turn into type 6 and then stop working, only turning FIPS off will make them work again as type 6 passwords.
