Troubleshooting Question
jain.manish94
Hello
what to do here
Please can you help me regarding this
Massive degradation in local network throughput
I just tested to copy a 4GB file from the network share to my local hard disk and it just gave me 1MByte/s where I would expect 100MByte/s.
It looks as if only the users in the 1st floor are affected. They are all attached to the switches sw1 ... -sw3. I just checked the link states on the switches and they are all ok except the fiber uplink on -sw1. This link intermittently switches between green and orange.
what i check here...
55 Replies 55
%NGWC_PLATFORM_FEP-1-FRU_PS_ACCESS: Switch 2: power supply B is not responding
why i am getting this issue each day from different-2 switches...
after reconnect the cable it is fixed.
Cisco Bug: CSCuv18572 - Suppress extra "power supply [X] is not responding" messages
Last Modified
Jun 06, 2016
Product
Cisco Catalyst 3850 Series Switches
Known Affected Releases
15.2(22.22)
Description (partial)
Symptom:
This is an enhancement bug to eliminate the false-positive log message seen on the 3850/3750x/3650x platforms.
%NGWC_PLATFORM_FEP-1-FRU_PS_ACCESS: Switch 6: power supply B is not responding
Conditions:
WS-C3850-x switches
WS-C3750X switches
WS-C3560X
Hello please reply on this question . please check attached file.
Q- As per the below snapshot, you can see, On 48port switch, 24 Port and the uplink port( from NM module) is connected on ASIC and the rest port is connected to another ASIC. How traffic flow from Port1 to Port25( Assume Stack cable is not connected).
i just copy this diagram threw internet and paste here. please reply ASAP.
PFA...
Hello please reply on this...
hello mark are u there please reply on this...
stack cable has nothing to do with how asics speak to each other internally
there are multiple ascis per switch and ports are assigned to each asic block
how they communicate together you need to ask Cisco that directly through TAC maybe they can answer it I cant I don't know what programming they use in their asics and I have no real requirement to know as you cant even access it
If you want to see what ports are assigned to each asic use
show platform pm platform-block
What is the meaning of it please reply..
LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0502.
Jul 21 11:57:02.106: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0003.
Jul 21 11:57:04.017: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0002.
Jul 21 11:57:29.395: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet2/2 on VLAN0502.
Jul 21 11:57:34.375: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0502.
Jul 21 11:57:42.108: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet2/2 on VLAN0002.
Jul 21 11:58:03.443: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet2/2 on VLAN0502.
Jul 21 11:58:12.671: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0502.
Jul 21 11:58:36.435: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0200.
Jul 21 11:58:40.280: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet2/2 on VLAN0002.
Jul 21 11:59:18.357: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet2/2 on VLAN0201.
Jul 21 11:59:19.375: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet6/1 on VLAN0999.
Jul 21 11:59:21.521: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet6/1 on VLAN0016.
Jul 21 11:59:22.020: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Port-channel2 on VLAN0305.
Jul 21 11:59:26.239: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port Port-channel2 on VLAN0315.
Jul 21 11:59:27.489: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet6/1 on VLAN0070.
Jul 21 11:59:28.492: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Port-channel2 on VLAN0826.
Jul 21 11:59:29.539: %SPANTREE-2-LOOPGUARD_BLOCK: Loop guard blocking port TenGigabitEthernet6/1 on VLAN0025.
Jul 21 11:59:30.341: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Port-channel2 on VLAN0824.
Jul 21 11:59:30.636: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.11.224 (Vlan24) is down: holding time expired
Jul 21 11:59:32.269: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Port-channel2 on VLAN0314.
Jul 21 11:59:33.871: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet6/1 on VLAN0046.
Jul 21 11:59:37.912: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet6/1 on VLAN0999.
Jul 21 11:59:40.197: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Port-channel2 on VLAN0311.
Jul 21 11:59:41.020: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.12.224 (Vlan25) is down: holding time expired
Jul 21 11:59:42.012: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port TenGigabitEthernet6/1 on VLAN0025.
1Gig link to Cardical was affected and due to which OSPF neig was down for second. It came back quicky-
Jul 21 11:59:42.329: %UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Te4/6, aggressive mode failure detected
Jul 21 11:59:42.329: %PM-4-ERR_DISABLE: udld error detected on Te4/6, putting Te4/6 in err-disable state
.Jul 21 11:59:42.526: %PM-4-ERR_DISABLE: STANDBY:udld error detected on Te4/6, putting Te4/6 in err-disable state
Jul 21 11:59:44.341: %OSPF-5-ADJCHG: Process 1, Nbr 10.122.122.1 on TenGigabitEthernet4/6 from FULL to DOWN, Neighbor Down: Interface down or detached
Jul 21 11:59:45.668: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.12.224 (Vlan25) is up: new adjacency
interface TenGigabitEthernet4/9
description SW-U3-Stack
Jul 21 11:59:47.456: %C4K_EBM-4-HOSTFLAPPING: Host 64:00:F1:06:79:53 in vlan 26 is moving from port Te4/9 to port Te4/1
Jul 21 11:59:48.207: %SPANTREE-2-LOOPGUARD_UNBLOCK: Loop guard unblocking port Port-channel2 on VLAN0313.
VLAN0001 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 2709 last change occurred 00:28:10 ago
          from TenGigabitEthernet1/6
VLAN0002 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 4366 last change occurred 00:28:12 ago
          from TenGigabitEthernet4/11
VLAN0003 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1232 last change occurred 00:28:12 ago
VLAN0004 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 20637 last change occurred 00:28:12 ago
VLAN0005 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 7814 last change occurred 00:28:12 ago
VLAN0006 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 2190 last change occurred 00:28:12 ago
VLAN0007 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 134195 last change occurred 00:28:12 ago
VLAN0008 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1194 last change occurred 00:28:12 ago
VLAN0009 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 139507 last change occurred 00:28:15 ago
VLAN0010 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 78817 last change occurred 00:27:30 ago
VLAN0011 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1200 last change occurred 00:28:15 ago
VLAN0012 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 20879 last change occurred 00:28:15 ago
VLAN0016 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 262036 last change occurred 00:27:37 ago
VLAN0020 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 4713 last change occurred 00:27:38 ago
VLAN0022 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 3900 last change occurred 00:27:35 ago
VLAN0023 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 4070 last change occurred 00:27:35 ago
VLAN0024 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 8770 last change occurred 00:27:37 ago
VLAN005 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 2245 last change occurred 00:27:39 ago
VLAN002 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 11325 last change occurred 00:03:19 ago
VLAN046 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 5710 last change occurred 00:01:04 ago
VLAN070 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 205 last change occurred 00:01:04 ago
VLAN012 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 4522 last change occurred 00:03:23 ago
VLAN020 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1272 last change occurred 00:28:17 ago
VLAN021 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1153 last change occurred 00:27:50 ago
VLAN02 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1159 last change occurred 00:27:50 ago
VLAN035 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 28419 last change occurred 00:02:43 ago
          from GigabitEthernet9/16
VLAN036 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 430 last change occurred 00:00:02 ago
VLAN030 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 7751 last change occurred 00:13:48 ago
          from TenGigabitEthernet4/3
VLAN038 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 20648 last change occurred 00:08:20 ago
VLAN009 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 35619 last change occurred 00:02:26 ago
          from TenGigabitEthernet6/2
  Number of topology changes 25024 last change occurred 00:01:23 ago
VLAN031 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 35582 last change occurred 00:00:42 ago
  Number of topology changes 61394 last change occurred 00:00:05 ago
          from TenGigabitEthernet5/2
VLAN033 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 16170 last change occurred 00:02:18 ago
          from TenGigabitEthernet4/7
  Number of topology changes 175 last change occurred 00:27:43 ago
  Number of topology changes 27002 last change occurred 00:01:39 ago
          from TenGigabitEthernet4/8
VLAN050 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 444 last change occurred 00:27:41 ago
VLAN053 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 238 last change occurred 00:27:43 ago
VLAN054 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 250 last change occurred 00:14:48 ago
  Number of topology changes 400 last change occurred 00:22:42 ago
VLAN080 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 287 last change occurred 00:08:31 ago
VLAN081 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 249 last change occurred 00:18:33 ago
VLAN022 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 308 last change occurred 00:10:39 ago
VLAN084 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 93 last change occurred 00:27:40 ago
VLAN026 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 91 last change occurred 00:27:40 ago
VLAN086 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 242 last change occurred 00:27:45 ago
VLAN089 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 247 last change occurred 00:17:29 ago
  Number of topology changes 714 last change occurred 00:00:03 ago
          from Port-channel2
VLAN099 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 170 last change occurred 00:27:43 ago
VLAN100 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 282 last change occurred 00:27:46 ago
Hello Mark ,
please can you tell me what does this means
show spanning-tree detail | inc ieee|occur|from|is exec
VLAN500 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 2616 last change occurred 00:05:47 ago
          from GigabitEthernet1/0/32
VLAN200 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 3856 last change occurred 00:33:37 ago
          from StackPort1
it tells you an STP- change came from that port GigabitEthernet1/0/32 5 minutes ago ,if you follow the port through cdp whats connected on it,  run the command again on next switch and so on until you find the source of the STP change
and
          from StackPort1
same thing only issue is coming from stackport , check where the TCN was generated from which switch which stackport
ok thank mark,
suppose i create one loopback on router 1 ok , what is the bandwidth of Loopback interface
when i run command
sh ip route on another router what it will show
O   11.0.0.2   110/?  via   20.0.0.2
i am running ospf and connected two router each other and created two loopback on each router
Please reply
Please open individual questions in separate posts and then mark and close the post when they have been answered so other users can benefit from the answers when searching issues its how the forum works
Hello mark,
please can you tell me that i can ping one of my website
ping oam.tsp.com
Ping is successfully.......
but when i am doing traceroute oam.tsp.com
it is not reaching , after MPLS Ip address i am getting
why please can you tell me.
mpls blocks traceroute its layer 2 labels not ip layer
