Troubleshooting Question
jain.manish94
Hello
what to do here
Please can you help me regarding this
Massive degradation in local network throughput
I just tested to copy a 4GB file from the network share to my local hard disk and it just gave me 1MByte/s where I would expect 100MByte/s.
It looks as if only the users in the 1st floor are affected. They are all attached to the switches sw1 ... -sw3. I just checked the link states on the switches and they are all ok except the fiber uplink on -sw1. This link intermittently switches between green and orange.
what i check here...
55 Replies 55
it is in live environment , please can you tell me. why we assign two mode on one port like access and trunk , you told me that trunk is overrules access when both configure , but why we need to configure both when only one can work.
You don't do that someone has incorrectly set the port , miss-configured it , it shouldn't be set like that its bad practice
Mark here are 2 ports with same configuration which are connected to each other from 1 switch to 2 second and i see that there is portchannel which is on trunk , so in that case it is possible
just because they are configured incorrectly does not mean they wont work , a po only cares about matching parameters does not care whether its a trunk or access
There is no requirement for access configuration when you have set the port as a trunk as well
access is for 1 vlan , trunks for multiple that's why trunks will take preference over access
ok
please can you tell me more about this
its multi layer switching netflow statistics for that address on the protocols you have specified tcp/upd/icmp
show mls netflow ip source 192.168.1.1 flow tcp/udp/icmp
in details
how is it helpful during troubleshooting..
Its only helpful if your troubleshooting netflow for that particular ip address in netflow , i dont use those commands as we use flow collector apps to visually see netflow issues with devices/ips
Its just going to show you the flow of traffic for that ip
Please can you provide me some troubleshooting command L1 or L2 label , which are very helpful to me.
Please share.
I'd say you have a faulty power supply.  You should replace the power supply.
but philip when i am running  sh env all command power supply is showing good..
Carlos Villagran
Hi!
Are you loosing pings if trying to ping from your PC to your gateway? (Router/SVI?).
Best regards!
I have two Nexus connected to an ASR 90000 series ROUTER on a bundle ether for redundancy. But recently a line card on one of the NEXUS went down and the bundle interface on the ASR went down too. Please what can be the cause and how do I prevent reoccurence.
