Troubleshooting Question
jain.manish94
Hello
what to do here
Please can you help me regarding this
Massive degradation in local network throughput
I just tested to copy a 4GB file from the network share to my local hard disk and it just gave me 1MByte/s where I would expect 100MByte/s.
It looks as if only the users in the 1st floor are affected. They are all attached to the switches sw1 ... -sw3. I just checked the link states on the switches and they are all ok except the fiber uplink on -sw1. This link intermittently switches between green and orange.
what i check here...
55 Replies 55
Please mark can you describe more about this. give some examples.
I don't have examples .but your using a layer 3 command over a layer 2 network so its not going to give a response at ip layer when it doesn't have any ips only uses labels
in that case how we can check , because issue is resolved but when i am checking from my core switch tracroute to that web site currently also not reaching , now how to check that it is working please tell me.
Most ISPs block traceroute through there mpls domain
Mark , the issue was
It was time sync issue...
5 min. difference between AD server in uk site and other servers
what is the relation between these , i am not getting this solution , do you have any idea...
No idea about AD sync I don't work on AD at all we have a systems team manages that side of IT
Hello Mark,
when i am running this command
sh spanning-tree details | in ieee|from|occur|is exec on ios switch i can but if i find any port where it is cat os on switch how to run this command please help me.
then why ping command is working for same website.
but why mpls blocks traceroute , it is helpful command to know where we are going then how we check for particular website.
only PE routers at the edge have ip addresses P routers internally in mpls don't layer 2 only  , 2nd reason is usually security they don't want you mapping there internal networks that are not publicly visible
Hello Mark ,
thank you very much for reply .
please can you tell me how to do this
Need to add aggregate route 10.172.84.0/21 on WAN Router and advertise the same towards the MPLS. We can leave /23 route as it is and add new route as aggregate route with /21.
Hello Mark,
Please check this configuration and reply me please
interface GigabitEthernet1/0/1
switchport access vlan 90
switchport trunk native vlan 10
switchport trunk allowed vlan 90,10
switchport mode access
udld port
how it is possible on access mode..
Its not access , if you do show g0/1 switchport it will state its a trunk port in trunk mode
trunk overrules access when both configured
Here is output.
sh int gigabitEthernet 1/0/1 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
why we need to configure two mode on one port . we can assign only
switchport mode trunk
switchport trunk allowed.
is it not enough ? ? ?
Its incorrectly configured should be set as access or trunk not both
