trunk interfaces not showing ?
tedauction
Hello, in the following C3650X-48 switch config, I have a number of trunk interfaces, however when I run the command 'sh int trunk' I do not see any trunks displayed.
Also when I run the command 'sh int gi0/1 trunk' it tells me there are no vlans allowed, however I have explicitly allowed vlan 35. Am I missing something here ?
Thank you kindly.
mySwitch(config-if)# do sh int trunk
mySwitch(config-if)#do sh int gi0/1 trunk
Port Mode Encapsulation Status Native vlan
Gi0/1 on 802.1q other 1
Port Vlans allowed on trunk
Gi0/1 none
Port Vlans allowed and active in management domain
Gi0/1 none
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 none
Current configuration : 10615 bytes
version 12.2
no service pad
service password-encryption
hostname mySwitch
boot-start-marker
boot-end-marker
logging buffered 409600
no aaa new-model
system mtu routing 1500
ip routing
no ip domain-lookup
login on-failure log
login on-success log
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1
description Link From IT Router
switchport trunk allowed vlan 35
switchport mode trunk
interface GigabitEthernet0/2
description Link to Cisco (VLAN 30)
switchport trunk allowed vlan 30
interface GigabitEthernet0/3
description Link to Cisco (VLAN 40)
switchport access vlan 40
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/4
switchport access vlan 30
interface GigabitEthernet0/5
description Kordia NIC (VLAN 4)
interface GigabitEthernet0/6
description Link to VF Multicast Audio port 2
interface GigabitEthernet0/7
description Golden Eagle
switchport access vlan 35
interface GigabitEthernet0/8
description Magic FM55 Processor
interface GigabitEthernet0/9
description GE UPS MGT
interface GigabitEthernet0/10
interface GigabitEthernet0/11
description Breeze Processor Optimod
interface GigabitEthernet0/12
description Processor
interface GigabitEthernet0/13
description Aserv
interface GigabitEthernet0/14
descriptione Aserv
interface GigabitEthernet0/15
description Aserv
interface GigabitEthernet0/16
description Aserv
interface GigabitEthernet0/17
description Aserv
interface GigabitEthernet0/18
description Aserv
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
shutdown
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
shutdown
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan30
ip address 10.21.210.2 255.255.255.0
interface Vlan35
ip address 10.23.40.2 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.21.210.1
no ip http server
ip http secure-server
ip access-list standard ACL_Restrict_SNMP
permit 10.21.250.0 0.0.0.255
permit 10.5.1.0 0.0.0.255
logging trap notifications
logging source-interface Vlan30
logging 10.21.250.23
snmp-server community precision RO ACL_Restrict_SNMP
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
2 Accepted Solutions
lpassmore
has the interface G0/1 actually connected as a trunk?  I think the 'other' in the status might be a clue.  This should say 'Trunking' if it is connected properly.
What does show interface G0/1 switchport show?
Does VLAN35 actually exist?  show vlan id 35?
Hello
Looks like the other side of the trunk isnt active?
res
Paul
Kind Regards
Paul
lpassmore
Hello
res
Paul
Kind Regards
Paul
