Trunk lines - management interface - default GW
joeadiutori
Hi All,
What is the default gateway of switch 2?  Assume trunk lines from router to switch, and from switch to switch.  The IP's on the switches are management interface VLAN's.  My initial thought is the router (10.0.0.1) is the default GW, but now I'm not so sure.
Thank You - Joe
Reza Sharifi
Hi Joe,
You are correct.  It is going to be 10.0.0.1 for both switch 1 and 2
Reza Sharifi
Hi Joe,
thanks for the info !!!
