Trunk to Trunk VLAN
Chieu Dinh
I have switch A interface 1/0/1 trunk (VLAN 1) is connecting to  switch B (VLAN2) interface 1/0/1 trunk. How do I route the packet from VLAN1 in switch A to VLAN 2 in switch B?
Switch A:
interface GigabitEthernet1/0/1
switchport mode trunk
interface Vlan1
  ip address 192.168.1.5 255.255.255.0
Switch B:
interface GigabitEthernet3/0/1
interface Vlan2
ip address 192.168.1.7 255.255.255.0
Thank you
Primary issue is resolved. Your vpn related issue can be resolved if your start new thread in VPN.
check your routes
if its same router on which vpn is configured it should ping router.
if its not same router you have to configured route for 192.168.15.x network.
*** DO RATE ALL HELPFUL POSTS ***
Jawad
Jawad
8 Replies 8
Is this your topology ?
############# trunk int 1/0/1 ------------------------------- int 1/0/1 trunk #############
      SW_A        SW_B
SW_A = vlan 1 192.168.1.5
SW_B = vlan 2  192.168.1.7
What is your native vlan? You need to have the same native vlan on SW_A and SW_B
If you don't have the same native vlan will not work.
SW_A
Switch(config)#interface vlan 99
Switch(config-if)#ip address 192.168.99.1 255.255.255.0
Switch(config-if)#no shutdown
Switch(config-if)#exit
Switch(config)#interface fastEthernet 0/1
Switch(config-if)#switchport mode trunk
Switch(config-if)#switchport trunk native vlan 99
SW_B
Switch(config-if)#ip address 192.168.99.2 255.255.255.0
If you want to route packets between vlans you have to implemente inter-vlan routing in a switch (L3) or router interface.
Reggards
Thank you for response.
I think my question is how do I route my packets between VLANs. and how do implement inter-vlan routing?
For the configuration above, I can set all in one native VLAN 1 which can work as it is. But I would like to route the packet between VLAN.
Is there something I have to set in VTP mode?
For Inter-vlan routing you need have a Layer 3 Switch or Router, and use it like a Default Gateway for the Host.
If you have a Layer 3 Switch ( example WS-C3750X-24T-S) you could be try the following:
Switch(config)#ip routing
Switch(config)#vlan 2
Switch(config-vlan)#exit
Switch(config)#vlan 3
Switch(config)#interface vlan 2
Switch(config-if)#ip address 192.168.2.1 255.255.255.0
Switch(config-if)#description DEFAULT-GATEWAY FOR VLAN 2
Switch(config)#interface vlan 3
Switch(config-if)#ip address 192.168.3.1 255.255.255.0
Switch(config-if)#description DEFAULT-GATEWAY FOR VLAN 3
Switch(config)#interface fa0/0
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 2
Switch(config-if)#switchport nonegotiate
Switch(config)#interface fa0/1
Switch(config-if)#switchport access vlan 3
Then connect a Host -> Fa0/0 and Fa0/1
For Host Fa0/0 configure the following addressing:
192.168.2.10
255.255.255.0
192.168.2.1    <- This is the interface vlan on the router, and is the default gateway for the host (vlan 2)
For Host Fa0/1 configure the following addressing:
192.168.3.10
255.255.255.0
192.168.3.1    <- This is the interface vlan on the router, and is the default gateway for the host (vlan 3)
Try executing ping between host, and this will be successful !
You can try this : "show ip route" to verify routing on the switch.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Reggards.
shamkuris
Hi Chieu Dinh,
For inter Vlan communication you need to have a L3 device such as router or a L3 swicth.
VLANs and trunks operate at layer 2. And at layer 2 you can not go between VLANs. To go between VLANs you need layer 3 such as a layer 3 switch or router.
Rick
Rick
switchport trunk allowed vlan 1,2
Create Vlan 2 alos here
int vlan 2
no shut
interface Vlan1
now u can assing this vlan to any port it will work
Switch B:
switchprot trunk allowed vlan 1,2
int vlan 1
no shut
interface Vlan2
assign any interface to vlan 1 here it will work
Remember vlan IP is used for managebility only.  both vlans in each switch should be UP.
Jawad
Jawad
I have this setup
int vlan 2
no shut
interface Vlan1
Switch B:
int vlan 1
no shut
interface Vlan2
It worked for the internal network. But when I connect my VPN into the network, I can't ping the router. The VPN is in the 192.168.15.0/24 network.
my VPN client can  ping any servers or client in the 192.168.1.0/24 network except the router 192.168.1.5
Any ideass?
check your routes
Jawad
Jawad
