Trunking configurations during upgrade
Ken S
What VLANs should be passed if the following configurations are on a 3750 to 2960x?
3750 (version 12.2(25)SEB4)
interface GigabitEthernet1/0/10
switchport mode trunk
2960x (version 15.2(7)E4)
interface GigabitEthernet1/0/49
switchport trunk allowed vlan 1,45,46,70,90,91,95,96,120,150,151
on a 3850 to 2960x
3850 (version 16.12.05b)
I did have switchport trunk encapsulation dot1q on the 3850, but that is not allowed on it.
I appreciate any assistance.
mlund
Level 7
Level 7
I agree with Reza and Balaji, it is best to have same config on both side.
But as an answer to your question, the vlans 1,45,46,70,90,91,95,96,120,150,151 is the ones that will be function in this configuration.
If there are vlan on 3850 side that is not allowed on 2960 side, they will be sent over the trunk to 2960, but 2960 will drop them because they are not in the allowed list.
/Mikael
14 Replies 14
Reza Sharifi
On the 3750, match the config that is already on the 2960X as follows:
Thank you @Reza Sharifi.  I did want to make the question more complex.  If the configuration stands as is, only the VLANs listed would be allowed correct?
It both sides had switchport trunk encapsulation dot1q, then all VLANs would be allowed through?
Hi Ken,
Yes, and that is best practice. You only want to allow what is needed and no more.
That is correct.
Except when I cutover the 3750 to 3850, it didn't seem the listed VLANs were being sent over.  The phones and APs on the 2960X didn't come back up.
Thank you for the clarification on the switchport trunk encapsulation dot1q.
Ken,
If you don't see the vlans sent over, check to make sure you actually have created all the vlans. Do a "sh vlan" and you should see what vlans you have created and what ports are assigned to each vlan.
Interesting note, but I do believe the VLANs were created on both switches due to VTP. I actually had this 3850 connected to the network and trunked to my office switch to upgrade it.  Also, I believe I was able to see another switch come up with phones, only when I added switchport trunk allowed vlan #,#,#.
I am sure that matching the allowed VLANs on both sides of the switches will work, but why didn't the original configuration for the 3850 and 2960X work?  Do I need both
to send VLANs over the trunk or just
switchport mode trunk?
Do I need both
Depends on the IOS. In most older IOS, you had to specify "switchport trunk encapsulation dot1q" because you could use dot1.q or ISL as trunking (ISL is a Cisco proprietary protocol that is not being used anymore). On most newer IOS versions, dot1.q is the default, and the only trunking protocol and therefore you don't need to specify it anymore.
As for using VTP, I personally do not recommend it as it can be more harmful than helpful especially when you only have a few vlans to worry about.
I am assuming that the IOS-XE has dot1q on my default and I am sure I verified that either on the 3850 I am working with or another one.  So essentially I would say I do have both
but the devices on the 2960X didn't come up.
VTP is another story.  Thank you for the feedback.
If all the vlans are present and assigned to the correct ports (show vlan) then check VTP, you may want to put VTP in "transparent mode" and see if the issue gets resolved. VTP is a pain.
balaji.bandi
is this 2 setup or 1 setup
I see you looking to connect 3750 to 2960 and 3850 to 2960 ?
always should match bot the side config.
if you like to control the vlan
you should go with both the side :
If you like to allow all vlan then :
both the side: switchport mode trunk (should allow all vlan)
On 3850 new IOX XE code so that should be ok. you just configure the required vlan along with trunk should work
any issue post any logs.
BB
Thank you @balaji.bandi. This is an upgrade.  A 3750 is connected to a 2960X, but I want to replace the 3750 with the 3850.
That is what I read about matching both sides.  It is good for many things, keeping good documentation is one of them.
When I cut over the 3750 to 3850, the interfaces with just switchport mode trunk didn't bring up the 2960X side.  This is why I am asking this question.  I could not add switchport trunk encapsulation dot1q to the 3850 as I think it might be removed.
I don't have any logs, but if this is a bug, I would be happy to work with Cisco.
I do not believe this is a bug :
you can verify this command, some command default in the interface
show interface GigabitEthernet1/0/10 capabilites
you see example output
Model: WS-C3850-48P
Duplex: full
Trunk encap. type: 802.1Q
Dot1x: yes
Since you mentioned outage. Now you need to test offline with out cutover
you can run 3750 and 3850 same time connecting to Cisco 2960 switch, test it  before you do cutover, i do not see any Loops herer, so you should be good for testing standalone.
BB
mlund
Level 7
Level 7
/Mikael
Thank you @mlund.  As I mentioned in a reply, same configs on both side is what I read.
Since the 3850 has
Those mentioned VLANs should be sent over, but the devices (phones, APs) on the 2960X didn't come up.
