Trunking on ASA
EvolutionVI
Hi all,
Have a question about trunking on an ASA5510. Here is my setup.
3Com switch VLAN300 = ports 5-8 and VLAN301 = ports 9-12. I have both VLANs trunked to port 13.
ASA5510 VLAN300 on ethernet0/3.300 and VLAN301 on ethernet0/3.301. Port 13 on the 3Com switch is attached to ethernet0/3 on the ASA. I assume the next step would be to trunk the two VLANs to ethernet0/3?
I tried to run the following commands:
ciscoasa(config)# interface ethernet0/3
ciscoasa(config-if)# switchport mode trunk
but i get an "Error: % Invalid input detected at '^' marker." The ^ is pointing to the switchport command. Any ideas?
Thanks for your help.
chris.lepa
You must do this:
asa(config)#int eth0/3
asa(config)#no shut
asa(config)#int eth0/3.300
asa(config-if)#encapsulation dot1q 300
asa(config-if)#ip add
asa(config-if)#no shut
asa(config)#int eth0/3.301
asa(config)#encapsulation dot1q 301
Hope that helps. Please rate if it does.
-Chris
Hi Chris,
Thanks for the info. I tried the command "encapsulation..." but it came up with the same error.
I was doing more research and apparently the ASA will automatically trunk the physical interface if more than 1 VLAN is added on that inteface. hmm...
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080636f42.html#wp1044006
One more question, I'm trying to get the two VLANs to communicate with each other but i'm having difficulties... here's my config:
interface Ethernet0/1
nameif outside
security-level 0
ip address x.x.x.2 y.y.y.y
ospf cost 10
interface Ethernet0/3
no nameif
no security-level
no ip address
interface Ethernet0/3.300
vlan 300
nameif vlan-inside
security-level 90
ip address 192.168.10.1 255.255.255.0
interface Ethernet0/3.301
vlan 301
nameif vlan-public
security-level 10
ip address 192.168.20.1 255.255.255.0
access-list vlan-inside_access_in extended permit ip any 192.168.20.0 255.255.255.0
access-list vlan-public_access_in extended permit ip any 192.168.10.0 255.255.255.0
nat-control
global (outside) 1 interface
global (outside) 2 x.x.x.3 netmask y,y,y,y
global (outside) 3 x.x.x.4 netmask y.y.y.y
global (vlan-inside) 3 interface
global (vlan-public) 2 interface
nat (vlan-inside) 2 192.168.10.0 255.255.255.0
nat (vlan-public) 3 192.168.20.0 255.255.255.0
access-group outside_access_in in interface outside
access-group vlan-inside_access_in in interface vlan-inside
access-group vlan-public_access_in in interface vlan-public
route outside 0.0.0.0 0.0.0.0 x.x.x.1 1
I can get out to the internet on both VLANs and they are going out on the right IPs. I just can't ping or get traffic to flow between VLAN 300 to VLAN301... any ideas?
Thanks for your help in advance.
glen.grant
Chris is correct you would need to use subinterfaces to trunk whatever vlans you want .
