trunking problem
enkli
Level 3
Level 3
Hello.
I have to connect two sites(I have connected them and everything works OK).
The problem is that I do not want that broadcasts come from one site to another.
So I have created another vlan on HQ and Remote SWITCH. I have set the port to witch the server is connected to trunk mode allowing the two VLANS.
So when I connet a computer on the remote site I cannot ping that. Any Idea
Giuseppe Larosa
hello Enkli,
only a L3 routed link is a firewall for broadcasts
a L2 trunk when working does not block broadcasts.
if 802.1Q trunk verify if native mismatch at the two sides of the link.
this can be a problem.
verify using
sh interface type x/y switchport
check for native vlan line
Hope to help
Giuseppe
LordFlasheart
Level 5
Level 5
Further to Giuseppe's answer you can remove VLANs from trunks by issuing the "switchport trunk allowed vlan remove" command.
hobbe
Level 11
Level 11
If you do not want broadcasts to come from site A to site B then you could do one of two things.
Routing, that would set the systems on the different sites in different broadcast domains.
ACL
Acces-control Lists on the outside interface of the switch where you block the inbound broadcast address.
I would go with routing.
The acls will most likely cause problems for you somewhere down the line.
Why do you not want broadcasts to go from A to B ?
Broadcasts are a quite essential part of IP if you are in the same subnet and broadcast zone.
