Trunking question
peter-net
Level 2
Level 2
Switch A is trunked to switch B and switch B is trunked to switch C (all 802.1Q).
Switch A has VLAN50 configured on it.
Switch B does not have VLAN50 configured on it.
Switch C has VLAN50 configured on it.
All switches are in VTP transparent mode.
Will VLAN50 traffic on switch A get to switch C?
5 Replies 5
keeleym
Level 9
Level 9
Hi Peter
I don't think that traffic from VLAN50 will get from Switch A to Switch C.
With the switches in transparent mode, each switch only knows about its own VLAN's. And even though you have a VLAN50 on Switch A and a VLAN50 on Switch B, these are not the same VLAN.
What you would need to do is to have all your switches as VTP Servers or 1 switch as a VTP server and the other 2 switches as clients. In this configuration all three switches would know about VLAN50 and even if switch B had no hosts in VLAN50 attached to it, it would still pass traffic for VLAN50 from switch A over the trunk to switch B.
Best Regards,
Michael
Edison Ortiz
No, unless you dot1q-tunnel that Vlan, but that's another exercise 🙂
__
Edison.
fernandezcarlos
Community Member
Transparent mode will not process VTP info across trunk BUT will send all packets.
With 3 2950's, I have setup trunks with the above config and a show interfaces trunk displays vlans 1-4096 allowed on trunks of all switches.
I also setup 2 pc's on switch A and C on Vlan 50 and was able to ping from one to the other.
Cheers
That's very interesting.
I would be interested to see switch B show spanning-tree vlan 50. If it has a spanning-tree for that VLAN, we must ask ourselves why. If it has no spanning tree for that VLAN, then that would imply that a transparent switch could cause a loop.
Did you try show vlan on switch B, just to be 100% sure there was no VLAN 50 there?
Kevin Dorrell
Luxembourg
You are right. Vlan 50 is configured on B. I was testing concept of transparent switches sending vlan 50 without server/client mode.
I did not notice "no vlan 50 on B" in original post.
Carlos
