trunking vlan issue
macboy276
Hi Everybody,
I have pasted the whole configuration of my cisco 3760 switch.
I have having a issue with vlan trunking
on ethernet port 1/0/1 i have configured switch mode trunk.
i have used the following command
switchport trunk nativ vlan 8
switchport trunk allowed vlan 1-10
If i use nativ vlan command then i get communication with the only described vlan. I want to be able to communicate with vlan 2 and 8.
switchport trunk nativ vlan 8 ( in this case if my laptop is configured with static ip address of vlan 3 it will not work) it will only work if laptop is configured with static ip from vlan 8
switchport trunk nativ vlan 2 ( in this case if my laptop is configured with static ip address of vlan 8 it will not work)it will only work if laptop is configured with static ip from vlan 2
i want to trunk in a way that i can access both vlan depending upon laptop configuration
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service sequence-numbers
hostname ABCD2013SW01
logging buffered 64000 debugging
no logging console
enable secret 5 ----------------------
enable password 7 -------------------
username badmin privilege 15 secret 5 $1$3xoh$Hpp2jaldsfjladsfj
username muadminas privilege 15 secret 5 $1$YJb6$sCdareljlkje9ff
aaa new-model
aaa authentication login CON local
aaa authentication login VTY local
aaa authentication enable default enable
aaa authorization exec default local
aaa session-id common
clock timezone CET -5
clock summer-time EDT recurring
switch 1 provision ws-c3750g-24ts-1u
vtp mode transparent
ip subnet-zero
no ip source-route
ip routing
ip icmp rate-limit unreachable 1000
ip domain-name xxxxxx.xxx
ip name-server 192.168.1.2
ip name-server 192.168.1.3
ip dhcp-server 192.168.1.3
no file verify auto
spanning-tree mode pvst
--More--         !
vlan internal allocation policy ascending
vlan 2
name inside
vlan 8
name Internal_LAN
interface Null0
no ip unreachables
interface GigabitEthernet1/0/1
description **LAN**
switchport mode trunk
no logging event link-status
spanning-tree portfast
interface GigabitEthernet1/0/2
description *** User Port ***
switchport access vlan 2
switchport mode access
interface GigabitEthernet1/0/3
switchport access vlan 8
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
--More--         !
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
  description **UPLINK**
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
no ip redirects
ip directed-broadcast
no ip proxy-arp
shutdown
interface Vlan2
description ** Management **
ip address 192.168.1.92 255.255.255.0
no ip redirects
no ip proxy-arp
interface Vlan8
description ** Internal_LAN **
ip address 172.168.1.92 255.255.255.0
ip helper-address 192.168.1.3
no ip redirects
no ip proxy-arp
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http authentication local
access-list 97 remark ** NTP-ACCESS **
access-list 97 remark ** NTP-Server
access-list 97 permit 192.168.1.3
access-list 97 deny   any log
access-list 98 remark ** SNMP-ny   any log
access-list 98 remark ** SNMP-ACCESS  **
access-list 98 permit 192.168.1.60
access-list 98 deny   any log
access-list 99 remark ** VTY_ACCESS **
access-list 99 deny   any log
access-list 99 permit 192.168.1.0 0.0.0.255
snmp-server community abiYHORHAEN RO
snmp-server chassis-id ABCD2013SW01
radius-server source-ports 1645-1646
control-plane
banner exec ^CCCCCCCCC
    VMWAFAR TECHNOLOGY
you are now connected to: $(hostname).$(domain)
^C
banner login ^CCCCCCCCC
**      banner                                                    **
**********************WARNING***************************************
*secure                                                            *
^C
line con 0
exec-timeout 30 0
login authentication CON
history size 30
transport output none
stopbits 1
line vty 0 4
access-class 99 in
exec-timeout 30 0
password 7 091D5EADKRCR130700
logging synchronous
login authentication VTY
length 0
history size 30
transport preferred none
line vty 5 15
access-class 99 in
exec-timeout 30 0
password 7 091D5E080138934450
logging synchronous
length 0
history size 30
ntp clock-period 36028917
ntp access-group peer 97
ntp server 192.168.1.7 prefer
end
17 Replies 17
alright, I was asking about that because you posted this before:
vlans in spanning tree forwarding state and not pruned
so it was just blank?
I'm just wondering if it has to do something with that portfast command.
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     2,8
But everything look ok right now so maybe you could try that wireshark sniff with ping or traceroute in promiscuous mode, to see if you receive any response.
Best regards,
Jan
I will wireshark too. Here is another thing
show vtp status
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 7
VTP Operating Mode              : Transparent
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xF3 0x57 0x0D 0x97 0x1F 0x75 0xF4 0xD1
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
I guess i did not mention earlier that i am trunking this switch with CISCO ASA 5505 Firewall. i have seen some people are complaining about this kind of senerio. i am attaching the ping and tracert wireshark report.
