Trunking
javier.moreno
Community Member
Why is it that I cannot use the show interfaces trunk command on a c2924xl en switch.
The switch is running c2900xl-c3h2s-mz.120-5.WC10.bin IOS.
Edison Ortiz
The command is:
show interface interface-id switchport
6 Replies 6
Edison Ortiz
The command is:
thank you for your help.
glen.grant
Because that switch is so old it does not use the same commands as newer ios switches.
I know that they are supper old but that is all that I can aford to buy to get ready for CCNA.
Understood I am just telling you the reason , there are differences between that old 2924 and say a 2950 as far as commands go and you should keep that in mind if are studying for certs because I believe they base the tests on a 2950 or higher.
