Trying to stack 2 c9300x-24Y with 2 c9300x-48TX switches. Same IOS.
rpanus
I am trying to stack 2 c9300x-24Y with 2 c9300x-48TX switches. All are running the same IOS. The 2 c9300x-24Y switches are switches 1 & 4 (top and bottom). The 2 c9300x-48TX switches are in positions 2 & 3.
When I run the show switch command on each switch, I only see like models of switches are stacked (1&4, 2&3). I have changed cables, reinstalled IOS, but to no affect. The stack originally started the same except for the 9300-tx switches were 9300-hx switches. Everything worked fine. The staging engineer realized the stack required 9300-tx's instead of the 9300-hx's. He powered down the stack and inserted the tx's where we realized the scenario described above. I have done a write erase on each switch, removed the priority commands, powered down, powered up, and so on. I had the staging guy replace all of the stack cables with brand new cables. We have configured hundreds of stacks over the past month or so without issue, but this is the first HX/Y attempt. Any ideas?
2 Accepted Solutions
rpanus
This configuration command was the solution: "switch stack-speed high". Make sure that this configuration parameter is on all switch stack members. Thanks for everyone looking into this for me.
looks good, can you post the configuration for the switch and also refer below troubleshooting guide :
Problem - C9300X Mixed Stack Splits into Sub-rings / Mismatched Stack Speeds
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/217684-verify-and-troubleshoot-stackwise-on-cat.html
BB
6 Replies 6
Leo Laohoo
All switch members (of the same stack) must be boot in Install Mode or Bundle Mode (and never a combination).
balaji.bandi
Provide some Logs while each switch booting time and joining stack
provide below output ;
show version
show switch
as asked home all installmode or bundle mode right ?
BB
Below are show ver, show mod, sh switch stack-ports, and show version. Keep in mind that all 4 switches are properly connected to one another via data stack cables. IOS upgrades used install mode and have the same IOS version. You will see that there are 2 separate stacks even though they are all stacked together. The stack ports show that switch one stack port 1 (connected to switch 2) is down, while stack port 2 (connected to switch 4) is up. Same idea for switches 2 and 3. Makes no sense to me. As I stated before, this same scenario worked when there were 2 c9300x-hx switches in the place of the c9300x-tx switches.
SWITCHES 1 & 4
Switch#show mod
Switch  Ports    Model                Serial No.   MAC address     Hw Ver.       Sw Ver.
 1       54     C9300X-24Y            FJC27311JKW  8c94.6135.7180  V02           17.09.04a
 2       54     C9300X-24Y            FJC27311GWV  6879.095b.7780  V02           17.09.04a
Switch#
Switch#sh swi
Switch/Stack Mac Address : 8c94.6135.7180 - Local Mac Address
Mac persistency wait time: Indefinite
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   8c94.6135.7180     15     V02     Ready
 2       Member   6879.095b.7780     12     V02     Ready
Switch#sh swi st
Switch#sh swi stack-p
Switch#   Port1     Port2
1         DOWN      OK
2         OK        DOWN
Switch#
Switch#sh ver
Cisco IOS XE Software, Version 17.09.04a
Cisco IOS Software [Cupertino], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.9.4a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2023 by Cisco Systems, Inc.
Compiled Fri 20-Oct-23 10:44 by mcpre
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.9.1r, RELEASE SOFTWARE (P)
Switch uptime is 12 minutes
Uptime for this control processor is 16 minutes
System returned to ROM by Reload Command
System image file is "flash:packages.conf"
Last reload reason: Reload Command
Technology Package License Information:
Technology-package                                     Technology-package
Current                        Type                       Next reboot
network-essentials      Smart License                    network-essentials
dna-essentials          Subscription Smart License       dna-essentials
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: Smart Licensing Using Policy
cisco C9300X-24Y (X86) processor with 1310642K/6147K bytes of memory.
Processor board ID FJC27311JKW
1 Virtual Ethernet interface
16 Ten Gigabit Ethernet interfaces
80 TwentyFive Gigabit Ethernet interfaces
8 Hundred Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
1638400K bytes of Crash Files at crashinfo-2:.
11264000K bytes of Flash at flash:.
11264000K bytes of Flash at flash-2:.
Base Ethernet MAC Address          : 8c:94:61:35:71:80
Motherboard Assembly Number        : 73-19730-06
Motherboard Serial Number          : FJZ2731MVJV
Model Revision Number              : D0
Motherboard Revision Number        : B0
Model Number                       : C9300X-24Y
System Serial Number               : FJC27311JKW
CLEI Code Number                   : INMGP00CRB
Switch Ports Model              SW Version        SW Image              Mode
*    1 54    C9300X-24Y         17.09.04a         CAT9K_IOSXE           INSTALL
     2 54    C9300X-24Y         17.09.04a         CAT9K_IOSXE           INSTALL
Switch 02
Switch uptime                      : 16 minutes
Base Ethernet MAC Address          : 68:79:09:5b:77:80
Motherboard Serial Number          : FJZ2731R535
System Serial Number               : FJC27311GWV
Last reload reason                 : Reload Command
END OF SWITCHES 1 & 4 OUTPUT
SWITCHES 2 & 3
Switch#show modu
 1       78     C9300X-48TX           FOC2713YFHJ  6c29.d253.c800  V02           17.09.04a
 2       78     C9300X-48TX           FOC2729Y23U  68e5.9e7c.f300  V02           17.09.04a
Switch#
Switch#sh sw
Switch/Stack Mac Address : 6c29.d253.c800 - Local Mac Address
                                             H/W   Current
*1       Active   6c29.d253.c800     14     V02     Ready
 2       Member   68e5.9e7c.f300     13     V02     Ready
Switch#   Port1     Port2
1         OK        DOWN
2         DOWN      OK
Switch#
Switch#sh ver
ROM: IOS-XE ROMMON
Switch uptime is 5 minutes
Uptime for this control processor is 9 minutes
cisco C9300X-48TX (X86) processor with 1310642K/6147K bytes of memory.
Processor board ID FOC2713YFHJ
112 Ten Gigabit Ethernet interfaces
32 TwentyFive Gigabit Ethernet interfaces
3887698K bytes of USB Flash at usbflash0:.
Base Ethernet MAC Address          : 6c:29:d2:53:c8:00
Motherboard Assembly Number        : 73-20261-04
Motherboard Serial Number          : FOC27070Y1R
Model Revision Number              : E0
Model Number                       : C9300X-48TX
System Serial Number               : FOC2713YFHJ
CLEI Code Number                   : INMGG00CRB
*    1 78    C9300X-48TX        17.09.04a         CAT9K_IOSXE           INSTALL
     2 78    C9300X-48TX        17.09.04a         CAT9K_IOSXE           INSTALL
Switch 02
Switch uptime                      : 9 minutes
Base Ethernet MAC Address          : 68:e5:9e:7c:f3:00
Motherboard Serial Number          : FOC272860SZ
System Serial Number               : FOC2729Y23U
END OF SWITCHES 2 & 3 OUTPUT
BB
rpanus
SWITCHES 1 & 4
Switch#show mod
Switch#
Switch#sh swi
                                             H/W   Current
Switch#sh swi st
Switch#   Port1     Port2
1         DOWN      OK
2         OK        DOWN
Switch#
Switch#sh ver
ROM: IOS-XE ROMMON
Switch 02
SWITCHES 2 & 3
Switch#show modu
Switch#
Switch#sh sw
                                             H/W   Current
Switch#   Port1     Port2
1         OK        DOWN
2         DOWN      OK
Switch#
Switch#sh ver
ROM: IOS-XE ROMMON
Switch 02
rpanus
