TtenGigabitEthernet Issue
Mohamed Gaber
I have 9200 switch with TtenGigabitEthernet Transceiver Module. Connected through (not sure but will confirm tomorrow) WDM to another switch.
sh inventory
NAME: "c92xxL Stack", DESCR: "c92xxL Stack"
PID: C9200L-24T-4X , VID: V01 , SN: XXXXXXXXXXX
NAME: "Switch 1", DESCR: "C9200L-24T-4X"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C5-125WAC , VID: V01 , SN: XXXXXXX
NAME: "Te1/1/4", DESCR: "1000BaseLX SFP"
PID: GLC-LH-SMD , VID: V01 , SN: XXXXXXX
when do "sh interf tenGigabitEthernet 1/1/4"
TenGigabitEthernet1/1/4 is up, line protocol is up (connected)
Hardware is Ten Gigabit Etherne
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
input flow-control is on, output flow-control is unsupported
Last input 02:06:19, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:46:44
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 3000 bits/sec, 5 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
15565 packets output, 1179815 bytes, 0 underruns
Output 4969 broadcasts (0 multicasts)
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
There is output but no input. The other side has the same "there is output but no input".
The strange is, when the fiber is connected to a fiber-To-UTP converter, it works. When connecting the fiber port of the converter to the TtenGigabitEthernet of the switch, it works also.
How to find out the problem source?
Reza Sharifi
GLC-LH-SMD
Referring to this part number, the connection is 1Gig and not a 10Gig.
As mentioned in "Cisco Catalyst 9200 Series Switches Hardware Installation Guide"
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/hardware/install/b-c9200-hig/b-c9200l-hig_chapter_01.html
4x10G ports that support either 1G SFP or 10G SFP+ modules.
And it works when it is connected to the converter. Show interface is up.
I don't know if it is a matter in the power of the received signal or something else.
I will try a command to display the received power.
