tunnelling layer 2 across a layer 3 network
jmcgrady1
I have need to present a given single vlan on two C9300 switches separated by a layer 3 network.  The presentation should be bidirectional and transparent. What would be the best kind of vpn setup to use?
balaji.bandi
VXLAN is the best option or xconnect
check the below guide also vpn :
https://www.cisco.com/c/en/us/support/docs/ip/layer-two-tunnel-protocol-l2tp/116266-configure-l2-00.html
This again depends on device options support and License.
BB
BTW, although @balaji.bandi 's reference does mention the reduction of payload due to encapsulation overhead, it doesn't explicitly mention this often leads to fragmentation (nor mitigation techniques).  Just mentioning this so it's not overlooked.
L2tp vpn or vxlan
MHM
