Turbo ACL
anasubra_2
Hi All,
Is turbo ACL feature is supported on Cisco 3845 router ?
Anantha Subramanian Natarajan
ajagadee
Anantha :-),
TurboACLs were deprecated on the ISR platforms starting with 12.4(15)T and this is
documented in the following DDTS.
CSCsg49131 - TACL code should not be there on the ISR platform
This is only specific to the ISR's (28xx and 38xx).
Arul
*Pls rate all helpful posts*
ajagadee
Anantha :-),
Arul
Hi Arul,
Thank you very much
