Two 802.1Q trunk links between two Layer2 switches
rawsonfang
I have two Cisco 6500 switches and plan to connect two switches together via Gigabit ports, we want to configure two links as separate trunks, and first trunk only allow even # VLAN to pass through it and the secondary trunk will only allow odd 3 of VLAN to pass through via command " switchport trunk allowed vlan xxx, xxx "
The question is that will this create Spanning tree loop issues betweeb the two switches. Or PVST feature still apply here.
Thanks in advance
Jon Marshall
No you should be fine as long as i understand you correctly ie. you have 2 trunks connecting a pair of 6500 switches. On trunk you are allowing the even vlans and on the other trunk you are allowing odd vlans.
Jon
Edison Ortiz
I agree with Jon, you shouldn't have any problems and actually that design is quite common as a Layer2 load-balancing design.
__
Edison.
Thanks for your advice.
