Two Cable Modems on Translated Vlan and LACP on Catalyst 3750
Hi!
I have two cable modems on two ISPs that I need to have their Vlan translated on the 3750 from "1" to "55" for one, and "1" to "494" for the other. I also need to have LACP on these 4 interfaces if possible. How do I do this?
marce1000
 - Use the switchport access vlan vlan-id  command to change the vlan a port will be operating in , for LACP  have a look at https://www.cisco.com/c/en/us/td/docs/ios/12_2sb/feature/guide/gigeth.html#wp1089298
 M.
Yes, but this doesn't translate the VLAN from 1 to 55.
For lacp since there is two different ISP router/modem then you can not
For vlan mapping check link below
https://ipcisco.com/lesson/vlan-mapping-vlan-translation-on-cisco/
This is incorrect. I don't have this command, and I CAN do LACP with BOTH cable modems.
