Two default routes not working
aparikh
6500 - version (s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF17a
I have two ISP's. I have created two defaults as follow & secondary route does not work.
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 0.0.0.0 0.0.0.0 Y.Y.Y.Y 200 (secondary route)
router eigrp 1
redistribute static
My Configuration :   ISP1<-->FW1<--->6513-1<---->6513-2<----->FW2<----->ISP2
        PC1
After disabling the interface to ISP1, backup routes does not work.
Any suggestion?
switch>sh ip route 0.0.0.0
6513-2#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "static", distance 1, metric 0, candidate default path
Redistributing via eigrp 8000
Advertised by eigrp 8000
Routing Descriptor Blocks:
* X.X.X.X
Route metric is 0, traffic share count is 1
Julio Carvajal
First of all,
If you check the Topology table on the Switch side (EIGRP neighbor) Do you see the feassible sucessor entry for that default route????
Let me know that,
Remember to rate all of the forum answers,
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
I see following route "sh ip eigrp topology
P 0.0.0.0/0, 1 successors, FD is 2816
        via Rstatic (2816/0)
