question about apply policy based routing to virtual template interface at preceding of radius server
Dr.X
Level 2
Level 2
hi ,
                                   radius server
assume i have , R1-----------SW-----------------R2
                                     R2
note that im applying pbr on a virtual template interface ,
i mean subnet x  ====> go to r2
and subnet y =======> go to r2
but im facing a problem , hwich is the AAA operation must be done between R1 and radius ,
and if i applied the pbr on R1 , the polivcy will be rejected , and go to normat routing table ,
i checked debug for pbr snd here is result :
Oct 15 15:49:37.902: IP: s=x.x.19.150 (Virtual-Access5), d=10.160.150.103, len 40, FIB policy match
Oct 15 15:49:37.902: IP: s=x.x.19.150 (Virtual-Access5), d=10.160.150.103, len 40, PBR Counted
Oct 15 15:49:37.902: IP: s=x.x.19.150 (Virtual-Access5), d=10.160.150.103, len 40, FIB policy rejected - normal forwarding
Oct 15 15:49:38.650: IP: s=x.x19.150 (Virtual-Access5), d=10.160.150.103, len 464, FIB policy match
Oct 15 15:49:38.650: IP: s=x.x.19.150 (Virtual-Access5), d=10.160.150.103, len 464, PBR Counted
Oct 15 15:49:38.650: IP: s=x.x.19.150 (Virtual-Access5), d=10.160.150.103, len 464, FIB policy rejected - normal forwarding
note that the ip
10.160.150.103
is the radius server ip !!!!!!!!!!!1
any advice ??
regards
srikanth ath
Level 4
Level 4
Hello
Kindly, represent the traffic flow with a clear diagram as so we can look into your issue.
srikanth
hi , im very sorry for  about the diagram ,
here is the diagram i  painted :
http://www12.0zz0.com/2012/10/16/17/677346880.png
regards
Ahmad
Hello
Sorry bro. i couldnt open this file, can u provide this in another format JPEG,  and attach it here.if you are unanble to provide this.
If someone can view above format, please help out/.
srikanth
