UCS connection to DMZ switch
MSL
As of now UCS 6248 is connected with N9K switches (4 X 10 Gb on vPC). We need to connect atleast 2 UCS blades with DMZ zone, the DMZ switch has 1 Gb ports available. Do we get an advice on connection from UCS to DMZ switch?
Thanks in advance
MSL
Still we are waiting for someone to response to this Question. We found an article on connecting disjoint networks with Cisco UCS (https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/unified-computing/white_paper_c11-692008.html). We plan to make configuration as mentioned below:-
  1. We will create new global VLANs (for eg:50, 51 & 52) for the DMZ, these VLANs will only be available to DMZ organization.
  2. The above mentioned VLANs will be assigned to uplinks connected to DMZ switch (from each FIs we connected port 1/10 to single DMZ switch)
    1. We configured port channel with upstream single DMZ switch, is this configuration needed or no need for port channel with upstream switch? With UCS vNICs we usually configure fabric level failover, that’s why we confused on Port channel with upstream switch, please clarify.
                 All other existing VLANs will be assigned to existing port channel which is connected to 2 X N9Ks.
     3. We are using both Microsoft HV 2016 & VMWare. We configured vNICs as mentioned below:-
HV 2016 Specific
VMWare Specific
*CSV_vNIC_FB
Using for CSV traffic, Single native VLAN configured
*LM_vNIC_FA
Using for Live Migration traffic, Single native VLAN configured
#vMotion_vNIC_FA
Using for vMotion traffic, Single native VLAN configured
*Mgmt_vNIC_FA
Using for Management traffic, Single native VLAN configured
#Mgmt_vNIC_FA
VM1_vNIC_FA
Assigned to Odd slot blades with multiple VLANs, using for VMs
VM1_vNIC_FA
VM2_vNIC_FB
Assigned to Even slot blades with multiple VLANs, using for VMs
VM2_vNIC_FB
* The 3 vNICs are assigned to all HV hosts                     # The 2 vNICs are assigned to all ESXi hosts
When we assign VLANs to uplinks / port channel receive below alert, hope these won’t affect any of these vNICs and connected VLANs in production
4. With the KB “https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/unified-computing/white_paper_c11-692008.html” it says to remove the default VLAN1 membership from upstream switch, do we need to remove default VLAN1 on all N9K & DMZ switches? (I believe it's not possible)
Than You
Any support please
