04-16-2022 04:32 PM
Hey, all, can anyone please give me some ideas? At my job, we have a 2960 cisco switch and we have some fetal monitors which use a UDP connection and not tcpip and cause dropping issues. When the connection from the monitor drops it makes the port on the switch flash orange /green then back and forth till we unplug the cable from the port and plug it back up or the nurse goes and restarts the monitor. I understand udp is a faster connection but we can't have dropping issues every time they are on i have looked at the switches they are set to stay alive.
04-16-2022 05:50 PM
invalid input when i do sh interface <port> controll
04-16-2022 06:13 PM
Did you substitute "<port>" for the port on the switch or did you blindly copy-and-paste everything?
04-16-2022 05:54 PM
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
SW17 uptime is 11 weeks, 3 days, 8 hours, 19 minutes
System restarted at 12:23:10 UTC Wed Jan 26 2022
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision D0) with 61440K/4088K bytes of memory.
Processor board ID FOC1148X3C4
Last reset from power-on
1 Virtual Ethernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1E:BD:1D:60:80
Motherboard assembly number : 73-10015-06
Power supply part number : 341-0098-02
Motherboard serial number : FOC114824UP
Power supply serial number : AZS114412D5
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C2960G-24TC-L
System serial number : FOC1148X3C4
Top Assembly Part Number : 800-26673-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : COM3G00BRB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 24 WS-C2960G-24TC-L 12.2(35)SE5 C2960-LANBASE-M
Configuration register is 0xF
