Unable to bring up a trunk port between cisco nexus and juniper EX4200 switchs
philippe.an
I'm facing an issue on interconnexion between nexus switchs and juniper switchs. My task is to create 2 links as a port-channel 2G between site A and B.
- On site A, I have 2 Cisco nexus 93180YC stacked.
- On site B, I have 2 Juniper EX4200 switches configured as virtual-chassis (=stacked).
On site A, on one Cisco Nexus, i have error on vPC status :
nexus-A# sh vpc 13
vPC status
Id Port Status Consistency Reason Active vlans
13 Po13 down* success success -
nexus-A# sh int eth 1/13
Ethernet1/13 is down (Link not connected)
admin state is up, Dedicated Interface
Belongs to Po13
Hardware: 100/1000/10000/25000 Ethernet, address: 00de.fbfb.5394 (bia 00de.fbfb.5394)
Description: V > Juniper
MTU 9000 bytes, BW 25000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
auto-duplex, auto-speed, media type is 1G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
nexus-A# sh lacp interface eth 1/13
Interface Ethernet1/13 is invalid
Channel group is 0 port channel is
PDUs sent: 0
PDUs rcvd: 0
Markers sent: 0
Markers rcvd: 0
Marker response sent: 0
Marker response rcvd: 0
Unknown packets rcvd: 0
Illegal packets rcvd: 0
Lag Id: [ [(0, 0-0-0-0-0-0, 0, 0, 0), (0, 0-0-0-0-0-0, 0, 0, 0)] ]
Operational as aggregated link since Thu Jan 1 01:00:00 1970
Local Port: Eth1/13 MAC Address= 0-de-fb-fb-53-87
System Identifier=0x8000, Port Identifier=0x8000,0x0
Operational key=0
LACP_Activity=passive
LACP_Timeout=Long Timeout (30s)
Synchronization=NOT_IN_SYNC
Collecting=false
Distributing=false
Partner information refresh timeout=Long Timeout (90s)
Actor Admin State=0
Actor Oper State=0
Neighbor: 0x0
MAC Address= 0-0-0-0-0-0
System Identifier=0x0, Port Identifier=0x0,0x0
Operational key=0
LACP_Activity=unknown
Collecting=false
Distributing=false
Partner Admin State=0
Partner Oper State=0
Aggregate or Individual(True=1)= 2
nexus-A# show int eth 1/13 transceiver det
Ethernet1/13
transceiver is present
type is 1000base-LH
name is CISCO
part number is FTLF1318P3BTL-C1
revision is A
serial number is FNS19280MKX
nominal bitrate is 1300 MBit/sec
Link length supported for 9/125um fiber is 10 km
cisco id is 3
cisco extended id number is 4
cisco part number is 10-2625-01
cisco product id is GLC-LH-SMD
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 35.66 C 90.00 C -10.00 C 85.00 C -5.00 C
Voltage 3.31 V 3.59 V 3.00 V 3.50 V 3.09 V
Current 21.54 mA 65.00 mA 1.00 mA 55.00 mA 3.00 mA
Tx Power -5.54 dBm 0.99 dBm -13.56 dBm -3.00 dBm -9.50 dBm
Rx Power -4.34 dBm 0.99 dBm -23.01 dBm -3.00 dBm -19.20 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
On the second Cisco Nexus, link is UP, vPC is UP.
nexus-B# sh vpc 13
vPC status
13 Po13 up success success 252,455,915
On both Cisco nexus, configuration is exactly the same and is simple.
Switch A and B :
nexus-B# sh run int eth 1/13
!Command: show running-config interface Ethernet1/13
!Time: Mon Jun 14 14:48:12 2021
version 7.0(3)I7(5a) Bios:version 05.31
description V > Juniper EX4200
switchport
switchport mode trunk
switchport trunk native vlan 999
switchport trunk allowed vlan 252,455,915
mtu 9000
channel-group 13 mode active
no shutdown
nexus-B# sh run int po 13
!Command: show running-config interface port-channel13
!Time: Mon Jun 14 14:49:23 2021
description PO> Juniper EX4200
switchport
mtu 9000
vpc 13
On site B, Juniper configs are like this :
Juniper> show configuration | display set | match ge-0/1/0
set interfaces ge-0/1/0 description "TK> To nexus-A"
set interfaces ge-0/1/0 ether-options 802.3ad ae0
Juniper> show configuration | display set | match ge-1/1/0
set interfaces ge-1/1/0 description "TK> To nexus-B"
set interfaces ge-1/1/0 ether-options 802.3ad ae0
Juniper> show configuration | display set | match ae
set interfaces ae0 description "T > Cisco Nexus"
set interfaces ae0 aggregated-ether-options minimum-links 1
set interfaces ae0 aggregated-ether-options link-speed 1g
set interfaces ae0 aggregated-ether-options lacp active
set interfaces ae0 unit 0 family ethernet-switching port-mode trunk
set interfaces ae0 unit 0 family ethernet-switching vlan members v455
set interfaces ae0 unit 0 family ethernet-switching vlan members v915
set interfaces ae0 unit 0 family ethernet-switching vlan members v252
set interfaces ae0 unit 0 family ethernet-switching vlan members v456
Summary : On switch nexus-A, Rx power on port is correct. I think i have logical issue (maybe on config or missing parameter) because I do not receive any PDU from juniper, PO13 is in NoOperMem status and port Eth1/13 is in NotConnected status.
Nevertheless, on the other endpoint juniper, port is UP and receive good signal too. To check the default link, I have configured cisco port and juniper port with IP adresses. I confirm that ping test was successful, meaning that there is no issue with SFPs, ports and fiber cables.
Do you have any explanation on this behavier and a solution to resolve this ?
Thank for help !
Philippe AN
balaji.bandi
still this is worry part as device not able to detect the SFP here i guess,
what is the outcome :  ( from Nexus A)
Other suggest, remove the Cable, default the Port to factory setup the port speed 1000 and insert the SFP make sure first detect SFP before connecting Link.
As you confirmed SFP are good. Make sure you swap the SFP and test it.
BB
