Unable to communicate between vlans
I currently have an Inter-Vlan routing network using a Layer 2 switch and a Layer 3 switch, the former one manages the vlan's ports for the clients and the latter routes the communications between them. I have a trunk cable between the switches in order to do so.
Each client can ping other members on the same vlan and all of the others' vlan gateway but cannot cross that barrier and cannot ping over to the client on the other vlan.
All the network is simulated on GNS3, the L3 switch is a Cisco IOU L3 version 15.7 and the L2 switch is a Cisco IOU L2 version 15.1a
I'll share you the configuration of both switches:
L2:
! Last configuration change at 02:36:37 UTC Mon Apr 17 2023
version 15.1
service compress-config
hostname IOU2
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain-lookup
no ipv6 cef
ipv6 multicast rpf use-bgp
spanning-tree mode pvst
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Ethernet0/0
switchport trunk allowed vlan 1-100
switchport mode trunk
duplex auto
interface Ethernet0/1
duplex auto
interface Ethernet0/2
duplex auto
interface Ethernet0/3
duplex auto
interface Ethernet1/0
switchport access vlan 10
switchport mode access
duplex auto
interface Ethernet1/1
duplex auto
interface Ethernet1/2
duplex auto
interface Ethernet1/3
duplex auto
interface Ethernet2/0
switchport access vlan 20
duplex auto
interface Ethernet2/1
duplex auto
interface Ethernet2/2
duplex auto
interface Ethernet2/3
duplex auto
interface Ethernet3/0
switchport access vlan 30
duplex auto
interface Ethernet3/1
duplex auto
interface Ethernet3/2
duplex auto
interface Ethernet3/3
duplex auto
interface Vlan1
no ip address
router eigrp 1
network 10.10.10.0 0.0.0.255
network 10.10.20.0 0.0.0.255
network 10.10.30.0 0.0.0.255
auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
L3:
version 12.4
no service dhcp
hostname ESW1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip routing
no ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vtp file nvram:vlan.dat
interface FastEthernet0/0
description *** Unused for Layer2 EtherSwitch ***
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface FastEthernet1/0
duplex full
speed 100
interface FastEthernet1/1
duplex full
speed 100
interface FastEthernet1/2
duplex full
speed 100
interface FastEthernet1/3
duplex full
speed 100
interface FastEthernet1/4
duplex full
speed 100
interface FastEthernet1/5
duplex full
speed 100
interface FastEthernet1/6
duplex full
speed 100
interface FastEthernet1/7
duplex full
speed 100
interface FastEthernet1/8
duplex full
speed 100
interface FastEthernet1/9
duplex full
speed 100
interface FastEthernet1/10
duplex full
speed 100
interface FastEthernet1/11
duplex full
speed 100
interface FastEthernet1/12
duplex full
speed 100
interface FastEthernet1/13
duplex full
speed 100
interface FastEthernet1/14
duplex full
speed 100
interface FastEthernet1/15
duplex full
speed 100
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 10.10.10.1 255.255.255.0
interface Vlan20
ip address 10.10.20.1 255.255.255.0
interface Vlan30
ip address 10.10.30.1 255.255.255.0
no ip http server
no ip http secure-server
ip forward-protocol nd
no cdp log mismatch duplex
control-plane
mgcp behavior g729-variants static-pt
banner exec
This is a normal Router with a SW module inside (NM-16ESW)
It has been preconfigured with hard coded speed and duplex
To create vlans use the command "vlan database" from exec mode
After creating all desired vlans use "exit" to apply the config
To view existing vlans use the command "show vlan-switch brief"
Warning: You are using an old IOS image for this router.
Please update the IOS to enable the "macro" command!
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
NETWORK:
2 Accepted Solutions
 The problem is in the L3 switch. You have the commamd "no ip routing". You need to run:
Conf t
 Ip routing
wr
rakuntal
The Problem is this
no aaa new-model
memory-size iomem 5
no ip routing
Solution
IP routing enable
IP routing not enabled on L3
7 Replies 7
Did you create the L2 VLANs on the L3 switch. Creating the VLAN interface does not automatically create the L2 instance. Make sure you configured all 3 L2 VLANs.
config t
vlan 10
vlan 20
vlan 30
end
-David
Conf t
 Ip routing
wr
rakuntal
The Problem is this
no aaa new-model
memory-size iomem 5
no ip routing
Solution
IP routing enable
It seemed to be the routing not being enabled. Thanks for the response and sorry for the error.
Sorry can you send me the image of l3sw you use in gns3 ?
Sure. Here it is
