unable to connecting two switches on different network
jawad.hussain
I am linking two different network layer 3 switches, I have made "ip routing" to link different vlans.
the ports connecting two switches i made to work as trunk, also tried to make same vlans on both switches and added the connecting port to same vlan but unable to ping them.
when I run cdp neibhours, it shows switch with domain name but no more details shown.Below are highlights of configuration..
DSL_Swtich#ping 150.1.3.1 (another switch 3650)
Sending 5, 100-byte ICMP Echos to 150.1.3.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
DSL_Swtich#
DSL_Swtich#
Success rate is 0 percent (0/4)
DSL_Swtich#show cdp nei
DSL_Swtich#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
Manar_HQ.manarhq.com
Gig 1/0/47 138 R S I WS-C3650- Gig 2/0/28
SERVER-SW Gig 1/0/46 128 S I WS-C2960X Gig 1/0/44
DSL_Swtich#
another switch side is :
pinging server switch
Kindly assist what show i make configuration to connect both swtich ping each other..
regards
Jawad
15 Replies 15
I am thankful to all of you.
I want to add some info for the future visitor that:
1. I make manual route to 2nd network by adding route add in PC/Server to 150.1.x.x
2. If I make route from switch to switch for whole network it will create traffic load as many clients don't need to forward on another network. ( to save unsual network traffic)
It means the network was approx ready remaining routing between VLANS...
I am again thankful to everyone.....
