Bookmark
Subscribe
2361
Unable to delete IOS from Flash
mahesh18
Level 6
Level 6
Hi all,
i have 3550 and i am upgrading the IOS.
Switch#delete flash:c3550-ipservicesk9-mz.122-40.SE
Delete filename [c3550-ipservicesk9-mz.122-40.SE]?
Delete flash:c3550-ipservicesk9-mz.122-40.SE? [confirm]
%Error deleting flash:c3550-ipservicesk9-mz.122-40.SE (Is a directory)
i did sh flash
Switch#sh flash
Directory of flash:/
    2  -rwx         285  Feb 28 1993 17:10:34 -07:00  info
    3  drwx         128  Feb 28 1993 17:13:59 -07:00  c3550-ipservicesk9-mz.122-40.SE
  406  -rwx         285  Feb 28 1993 17:14:38 -07:00  info.ver
  407  -rwx         580  Mar 21 2010 15:09:27 -06:00  vlan.dat
  409  -rwx        2821  Mar 21 2010 15:50:45 -06:00  config.text
  410  -rwx          24  Mar 21 2010 15:50:45 -06:00  private-config.text
  411  -rwx        1048  Mar 21 2010 15:50:45 -06:00  multiple-fs
it shows that current IOS is drwx  so how can i delete the c3550-ipservicesk9-mz.122-40.SE
many thanks
mahesh
2 Accepted Solutions
glen.grant
It's a directory so you have to use " del /force /recursive flash:c3550-ipservicesk9-mz.122-40.SE  .
Yes you are ready to go.
7 Replies 7
glen.grant
Hi glen
thanks for great reply
i did following
Switch#copy tftp://192.168.1.8/c3550-ipbase-mz.122-44.SE6.bin flash:
Destination filename [c3550-ipbase-mz.122-44.SE6.bin]?
Accessing tftp://192.168.1.8/c3550-ipbase-mz.122-44.SE6.bin...
Loading c3550-ipbase-mz.122-44.SE6.bin from 192.168.1.8 (via Vlan1): !OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!
[OK - 6719771 bytes]
6719771 bytes copied in 146.552 secs (45852 bytes/sec)
Switch#sh flash
    3  -rwx     6719771  Mar 21 2010 20:33:01 -06:00  c3550-ipbase-mz.122-44.SE6.bin
just want to make sure that ios is copied successfully as i see O in the output
thanks
mahesh
Use the verify command to make sure it is the same as the one posted on CCO before rebooting
verify /md5 flash:/image_name
HTH,
jerry
thanks for help
here is output
Switch#verify /md5 flash:/c3550-ipbase-mz.122-44.SE6.bin
...................................................................Done!
verify /md5 (flash:/c3550-ipbase-mz.122-44.SE6.bin) = 9fab1c87835b467b998bb917135786c5
does it shows i am all set?
Hi leolaohoo
thanks for confirming it.
one last question what does O  mean while IOS was being copied to flash?
does it mean slowness?
mahesh
It's good that you ask.  In my humble experience, when you get "O" and your upgrade failed, mostly it's because there's not enough flash memory space.  You won't get the explaination of "not enough space" when you are dealing with old appliance such as the 2900/3500 but starting from the 2940/2950 and up (not sure about the 2948G).
Now, when you get "O" but your upgrade is successful, it only means that your WAN/LAN link is pretty slow.  (Like pumping a 2900XL IOS using a 256k satellite link, lucky I didn't have heart attack!)
Hope this helps.
