Unable to get a LACP connection to work between a 2960 and C9300-48-UXM-E
Ignore the name, I am working on a 3 switch stack (using Stackwise 480)
C9300 config
C9300_Stack_Member_3(config)#$interface range tengigabitEthernet 1/0/40, tenGigabitEthernet 2/0/40
C9300_Stack_Member_3(config-if-range)#switchport mode trunk
C9300_Stack_Member_3(config-if-range)#switchport trunk allowed vlan 2-4,81,91
C9300_Stack_Member_3(config-if-range)#channel-group 6 mode active
C9300_Stack_Member_3(config-if-range)#exit
C9300_Stack_Member_3(config)#exit
2960 Config
AudioRack(config)#interface range tenGigabitEthernet 1/0/1-2
AudioRack(config-if-range)#switchport mode trunk
AudioRack(config-if-range)#switchport trunk allowed vlan 2-4,81,91
AudioRack(config-if-range)#channel-group
AudioRack(config-if-range)#channel-group 1 mode passive
AudioRack(config-if-range)#exit
On the c9300:
C9300_Stack_Member_3#show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 7
Number of aggregators: 7
Group Port-channel Protocol Ports
1 Po1(SU) LACP Te1/0/48(P) Te2/0/48(P)
2 Po2(SU) LACP Te1/0/46(P) Te1/0/47(s)
Te2/0/46(P) Te2/0/47(s)
3 Po3(SU) LACP Te1/0/45(P) Te2/0/45(P)
4 Po4(SU) LACP Te1/0/44(P) Te2/0/44(P)
5 Po5(SU) LACP Te1/0/43(P) Te2/0/43(P)
6 Po6(SD) LACP Te1/0/40(s) Te2/0/40(s)
8 Po8(SU) LACP Te1/0/38(P) Te2/0/38(P)
C9300_Stack_Member_3#show interfaces etherchannel
TenGigabitEthernet1/0/40:
Port state = Up Cnt-bndl-rmt Suspend Mstr Rmt-LACP_Dsbl Not-in-Bndl
Channel group = 6 Mode = Active Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po6
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Te1/0/40 SA susp 32768 0x6 0x6 0x129 0x7D
Age of the port in the current state: 0d:00h:14m:07s
TenGigabitEthernet2/0/40:
Local information:
Te2/0/40 SA susp 32768 0x6 0x6 0x229 0x7D
Age of the port in the current state: 0d:00h:14m:31s
Port-channel6:Port-channel6 (Primary aggregator)
Age of the Port-channel = 0d:01h:18m:00s
Logical slot/port = 35/6 Number of ports = 0
HotStandBy port = null
Port state = Port-channel Ag-Not-Inuse
Protocol = LACP
Port security = Disabled
Fast-switchover = disabled
Fast-switchover Dampening = disabled
Time since last port bundled: 0d:00h:28m:36s Te2/0/40
Time since last port Un-bundled: 0d:00h:21m:36s Te2/0/40
2960
AudioRack#show etherchannel summary
U - in use N - not in use, no aggregation
m - not in use, port not aggregated due to minimum links not met
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
1 Po1(SD) LACP Te1/0/1(s) Te1/0/2(s)
AudioRack#
AudioRack#show interfaces etherchannel
TenGigabitEthernet1/0/1:
Channel group = 1 Mode = Passive Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po1
Local information:
Te1/0/1 SP susp 32768 0x1 0x1 0x11C 0x7C
Age of the port in the current state: 0d:00h:14m:39s
TenGigabitEthernet1/0/2:
Local information:
Te1/0/2 SP susp 32768 0x1 0x1 0x11D 0x7C
Port-channel1:Port-channel1 (Primary aggregator)
Age of the Port-channel = 73d:04h:42m:17s
Logical slot/port = 9/1 Number of ports = 0
Protocol = LACP
Load share deferral = Disabled
Time since last port bundled: 0d:00h:38m:48s Te1/0/2
Time since last port Un-bundled: 0d:00h:30m:15s Te1/0/2
AudioRack#
I have been beating my head on a wall for 3 hours on this, and I just cannot see what is causing this.
Any help is greatly appreciated
Thx
Bryan
Leo Laohoo
What happens if this is changed to "active"?
Hi Leo
No change.
I have tried
2960           9300
Active          Active
Active          Passive
Passive        Active
Passive        Passive
Thx
Bryan
And what firmware is the 9300 running on?
Is the 9300 firmware loading on Install or Bundle Mode?
And what log entries show up when the ports are bounced?  Are the ports suspended due to speed mismatch?
balaji.bandi
Hope we have suggested another posts always use LACP where possible when cisco to cisco connecting (until other reasons here to testing purpose ) ?
the port channel in suspended, so there is an issue, what you see in the Logs  ? is this suspended due to security reasons? what reason?
take a small break, think about what is not working,
1. is this Physical port working as an individual
2. reset the config of the interface to default and start over 1 step at a time,
3. do not make any major changes, so you have control over what is working and what is not working.
4. make sure you have both the side right optics (SFP) - do not connect 10GSFP to 1GSFP?
BB
