Unable to ping between VLANS with a Cisco 2811 using a 16 port switch module
Kyle C Barnes
Hello!
Pretty basic setup...
2 VLANS:
10.0.0.0/24 and 10.0.100.0/24
SVI for the first one is 10.0.0.1 and the SVI for the second is 10.0.100.1.
I've configured two DHCP pools as follows:
ip dhcp pool Home_Data
   network 10.0.0.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4
   default-router 10.0.0.1
ip dhcp pool Home_Wireless
   network 10.0.100.0 255.255.255.0
   default-router 10.0.100.1
Connected devices pull an IP and can get out to the internet just fine.  I've found that devices on separate VLANs are unable to talk to one another.  I have IP routing enabled and there are no ACLs.
Test...
Barnes_Router#ping 10.0.0.2
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Barnes_Router#ping 10.0.100.2
Sending 5, 100-byte ICMP Echos to 10.0.100.2, timeout is 2 seconds:
Packet sent with a source address of 10.0.0.1
Success rate is 0 percent (0/5)
Packet sent with a source address of 10.0.100.1
Routing table for those interested
     10.0.0.0/24 is subnetted, 3 subnets
C       10.0.0.0 is directly connected, Vlan100
C       10.0.50.0 is directly connected, GigabitEthernet1/0
C       10.0.100.0 is directly connected, Vlan200
S*   0.0.0.0/0 [1/0] via 10.0.50.1
Why the hell can't they talk!?
Thanks!
Kyle
Can you disable windows software firewall  on both machines and try again.
To test inter vlan routing you should ping a SVI address sourcing from other SVI.
Alain
6 Replies 6
Rejohn Cuares
Level 4
Level 4
Could you please attach your full config.
Please rate replies and mark question as "answered" if applicable.
Jeff Van Houten
Level 5
Level 5
Do you have the Vlans defined. In the vlan database? Defining an svi is not enough.
They are defined in the VLAN database.  Thanks so far!
Alain
Host on each vlan can acces the Internet but not inter-vlan?
I suggest enabling debug ip packet detail on this router with a filter so you will get only the interesting traffic. Dont forget to disable IP CEF. Then perform a ping from vlan 100 to Vlan 200. Also post the Output of show vlan-switch.
