Unable to ping directly connected device SVIs and Sub-interfaces
CiscoBrownBelt
Level 6
Level 6
So I have 2 directly connect switch and router. I can ping all SVIs on the Sw but the switch I can only ping the g0/0/0.252.1 (HSRP so .2 as well) interface.
All SVI and sub-int are up.
Trunk from switch to Router is allowing all VLANs.
Have static routes on router for SVIs on Router and have a default route for everything pointing to Router on the Switch.
Any help guys?
Also have issue pinging from Int Sw Prim to any SVI on Access Sw and the IP of the directly connected inside interface of the FW but I would like to tackle this issue first.
See attachment of topology.
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0/0
description Link2_Sw0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/0/0.12
encapsulation dot1Q 12
ip address 10.10.12.1 255.255.255.0
interface GigabitEthernet0/0/0.14
encapsulation dot1Q 14
ip address 10.10.14.1 255.255.255.0
interface GigabitEthernet0/0/0.252
description NE_Mgmt
encapsulation dot1Q 252
ip address 192.168.252.2 255.255.255.0
standby 1 ip 192.168.252.1
standby preempt
standby 0 track GigabitEthernet0/0/1
interface GigabitEthernet0/0/1
description Link2_FW
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/1.251
encapsulation dot1Q 251
ip address 192.168.251.2 255.255.255.0
standby 2 ip 192.168.251.1
standby 2 preempt
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.250.0 255.255.255.0 192.168.252.5
ip route 192.168.200.0 255.255.255.0 192.168.252.5
ip route 192.168.180.0 255.255.255.0 192.168.252.5
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
IntRr_Prim#sh ip int br
GigabitEthernet0/0/0 unassigned YES unset up up
GigabitEthernet0/0/0.1010.10.10.1 YES manual up up
GigabitEthernet0/0/0.1210.10.12.1 YES manual up up
GigabitEthernet0/0/0.1410.10.14.1 YES manual up up
GigabitEthernet0/0/0.252192.168.252.2 YES manual up up
GigabitEthernet0/0/1 unassigned YES unset up up
GigabitEthernet0/0/1.251192.168.251.2 YES manual up up
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
description Link2_Rt0
switchport mode trunk
interface GigabitEthernet0/2
description Link2_Sw1
interface Vlan1
no ip address
shutdown
interface Vlan180
mac-address 0001.c9cc.0e01
ip address 192.168.180.1 255.255.255.0
interface Vlan200
mac-address 0001.c9cc.0e02
ip address 192.168.200.1 255.255.255.0
interface Vlan250
mac-address 0001.c9cc.0e03
ip address 192.168.250.1 255.255.255.0
interface Vlan252
description NEMgmt
mac-address 0001.c9cc.0e04
ip address 192.168.252.5 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.252.1
line con 0
line aux 0
line vty 0 4
login
end
GigabitEthernet0/2 unassigned YES unset up up
Vlan1 unassigned YES unset administratively down down
Vlan180 192.168.180.1 YES manual up up
Vlan200 192.168.200.1 YES manual up up
Vlan250 192.168.250.1 YES manual up up
Vlan252 192.168.252.5 YES manual up
12 Replies 12
Francesco Molino
Can you share your packet tracer file to take a look at it please?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Deepak Kumar
HI,
I think best to share your PT file.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi sorry I am not quite sure how to get the file right now.
Ok so if I create an SVI on the switch for each sub-interface subnet on the router that I could not ping it worked. I am not sure why that is the case if I have a
0.0.0.0 0.0.0.0  (router ip) default route. Can you help me understand why?
I don’t understand what’s not working.
What ping are you doing:
 - source ip and destination
From the switch to the router?
Francesco
Ping from switch to any other IP address on router except the .252 which works.
I am only able to ping the other IP addresss/interfaces on the router if I create a SVI for that subnet on the switch. Once again I don't see why when I have  a default route pointing to the router.
Share your packet-tracer file to take a look.
When you ping another interface of your router from the switch and you run debug icmp on your router what's the output? Can you share it?
Route seem to be there.
Francesco
So when I enter debug ip icmp on both swith and router it does not show anything.
After some testing however, I noticed that if I create an SVI on the Intsw and the IntRt has a corresponding sub-int, I can only ping the sub-int if it is on the directly connected interface (interface between Int switch and Router) and vice versa. So if I remove or shutdown the SVI for those subnets on the Intswitch I can ping.
The main thing I want to be able to do is pass all traffic that is destined for the FW through the IntSw and all traffic that is destined for the InterRt from the FW be passed through as well.
Right now the connection g0/1 from the IntSw to the IntRt is trunked - can ping but only if I don't create SVIs for subnets that are not configured on the directly connected interface of the router, and the port connection on the IntSw that connects to the FW is switchport access vlan for the same subnet of the inside interface of the FW - I can't get it to ping if I make this connection a trunk.
Will all internal subnet traffic that is destined for the FW from the IntRt and vice versa pass through the switch this way?
On which switch are you connected to? Layer 3 or Layer 2?
I mean if your laptop on the switch is on a vlan where the default gateway is on the switch, then you can ping all subnets because it’s inter vlan routing.
However, if your host is on a switch that acts as default gateway, you need to activate ip routing on this switch to make sure you can reach subnets on router side.
Have you activated ip routing?
That’s why I asked for your packet tracer file because we can open it and check where the issue is and point it out to you.
Francesco
I am pinging directly from the Layer 3 switch and IP routing is enabled.
I mean if your laptop on the switch is on a vlan where the default gateway is on the switch, then you can ping all subnets because it’s inter vlan routing. I can connect a laptop and try.
I am not sure how to get the packet tracer file.
See configs.
InterConSw_Prim#sh run
Building configuration...
Current configuration : 1836 bytes
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname InterConSw_Prim
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
description Trunk2_InterRt_Prim
switchport access vlan 251
switchport mode access
switchport nonegotiate
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 000c.cf26.8701
ip address 10.10.10.7 255.255.255.0
interface Vlan40
mac-address 000c.cf26.8702
ip address 192.168.40.7 255.255.255.0
interface Vlan251
mac-address 000c.cf26.8703
ip address 192.168.251.7 255.255.255.0
interface Vlan252
mac-address 000c.cf26.8704
ip address 192.168.252.7 255.255.255.0
ip classless
ip route 192.168.252.0 255.255.255.0 192.168.251.1
ip route 192.168.0.0 255.255.0.0 192.168.251.1
ip route 10.10.0.0 255.255.0.0 192.168.251.1
line con 0
line aux 0
line vty 0 4
login
end
Vlan10 10.10.10.7 YES manual up up
Vlan40 192.168.40.7 YES manual up up
Vlan251 192.168.251.7 YES manual up up
Vlan252 192.168.252.7 YES manual up up
IntRr_Prim#sh run
Current configuration : 1659 bytes
version 15.4
hostname IntRr_Prim
ip cef
no ipv6 cef
interface Loopback1
ip address 10.10.0.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/0.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
description NE_Mgmt
standby preempt
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/1.40
no ip address
standby 2 preempt
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.251.251
line con 0
line aux 0
line vty 0 4
login
end
GigabitEthernet0/0/0 10.10.0.1 YES manual up up
GigabitEthernet0/0/0.40192.168.40.1 YES manual up up
GigabitEthernet0/0/1.40unassigned YES unset up up
Loopback1 1.1.1.1 YES manual up up
IntRr_Prim#
PINGS - basically if I shut down the SVI on the Interconnect swtich  I have for a sub-int that is not on the directly connect intreface on the router I can ping. I Shutdown SVI 252 but for some reason I still can't ping now which is weird as I though I could before. See below.
InterConSw_Prim#ping 192.168.252.1
Sending 5, 100-byte ICMP Echos to 192.168.252.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
InterConSw_Prim(config)#interface vlan 10
InterConSw_Prim(config-if)#shut
%LINK-5-CHANGED: Interface Vlan10, changed state to administratively down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to down
end
InterConSw_Prim#
%SYS-5-CONFIG_I: Configured from console by console
InterConSw_Prim#ping 10.10.10.1
Sending 5, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/1 ms
InterConSw_Prim#
InterConSw_Prim#ping 10.10.12.1
Sending 5, 100-byte ICMP Echos to 10.10.12.1, timeout is 2 seconds:
IntRr_Prim#ping 192.168.252.7
Sending 5, 100-byte ICMP Echos to 192.168.252.7, timeout is 2 seconds:
On your switch, this route is useless:
On your router, you’re also missing some routes for 192.168.251.0/24, 192.168.40.0/24
Also what’s strange is that your Intswitch Primary has 192.168.252.0/24 subnet and you have the same on your access switch but there are separated by a router and are not connected together. How did you span your vlan because I don’t see any L2 link and what you’re doing is not correct.
You can take your pka file saved from your default packet-tracer location, you can save at a new location.
Francesco
Sorry I was making some changes to test and left that. I removed it.
I was making changes again. Also see Access Switch config below.
I entered routes for all the subnet on the Access switch  for 192.168.251.5
Didn't enter one for 192.168.252.5 because I could always ping it. This correct?
Here my routes on IntRt. These would all be correct?
ip route 10.10.12.0 255.255.255.0 192.168.252.5
ip route 10.10.10.0 255.255.255.0 192.168.252.5
I have a default route for 0.0.0.0 0.0.0.0 192.168.251.251 and still does not work.
Looks like that was my problem. I don't know another way but I connected a trunk between the Accesssw and the InterconSw and now I can ping all sub-interfaces and SVIs!!
I am merely using the InterConsw just so I can connect the 2 routers to 1 FW somehow. I just need whatever traffic destined for the FW to pass-though the switch.
How do you suggest I connect to that switch or SPAN that 252 VLAN across all devices if what is did is not the best practice?
That 252 subnet is used for or at least I am trying to use for mgmt. The access switch is connected to the IntRt via trunk and likewise for the IntRt connected to the IntSw. How do you suggest I change this if I want to use 192.168.252. for true OOB mgmt?
ServerAccSw# sh run
Current configuration : 2474 bytes
version 12.2(37)SE1
hostname ServerAccSw
ip routing
switchport access vlan 180
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.10.10.5 255.255.255.0
interface Vlan12
ip address 10.10.12.5 255.255.255.0
interface Vlan14
mac-address 0001.c9cc.0e09
ip address 10.10.14.5 255.255.255.0
interface Vlan40
mac-address 0001.c9cc.0e0a
ip address 192.168.40.5 255.255.255.0
interface Vlan51
ip address 192.168.51.5 255.255.255.0
shutdown
interface Vlan180
interface Vlan200
mac-address 0001.c9cc.0e05
interface Vlan250
mac-address 0001.c9cc.0e06
interface Vlan251
mac-address 0001.c9cc.0e07
ip address 192.168.251.5 255.255.255.0
interface Vlan252
description NEMgmt
mac-address 0001.c9cc.0e08
ip classless
ip route 192.168.50.0 255.255.255.0 192.168.252.6
ip route 10.10.0.0 255.255.0.0 192.168.252.1
ip route 192.168.51.0 255.255.255.0 192.168.252.6
PING
Vlan10 10.10.10.5 YES manual up up
Vlan12 10.10.12.5 YES manual up up
Vlan14 10.10.14.5 YES manual up up
Vlan40 192.168.40.5 YES manual up up
Vlan51 192.168.51.5 YES manual administratively down down
Vlan251 192.168.251.5 YES manual up up
Vlan252 192.168.252.5 YES manual up up
ServerAccSw#ping 192.168.251.1
Sending 5, 100-byte ICMP Echos to 192.168.251.1, timeout is 2 seconds:
ServerAccSw#ping 192.168.252.1
ServerAccSw#ping 10.10.14.1
Sending 5, 100-byte ICMP Echos to 10.10.14.1, timeout is 2 seconds:
See packet tracer device configs and topology in attachment.
