04-29-2018 04:50 PM - edited 03-08-2019 02:50 PM
Folks,
I ran into a problem this afternoon and I can't find the cause or solution.
I have a Cisco 3750G in a LAN, I have a PoE device connected to port #16, configure as access port. The device is a Unifi Cloud Key which is powered and the lights are blinking green on the switch which shows that the port is working. Then I noticed that randomly the light on the switch for port #16 starts going from green to amber for 5-10 seconds, then goes back to green and so on. I have no connectivity whatsoever on this port no matter what color is the light.
Now, I tried to connect a laptop on port #16 and it worked properly (minus a few crc/input errors). Then I connected my Unifi Could Key into port #15 and it worked properly as well. Both ports are access port with the same parameters (unless I missed something).
For now I left my cloud key in port #15 as it is working properly. Any idea what the problem might be?
Thanks!
Dom
04-30-2018 12:13 AM
04-30-2018 04:26 AM
Hello Leo,
Thanks for helping me out with this issue. This is the output for that command:
GigabitEthernet1/0/16 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ec30.9115.eb10 (bia ec30.9115.eb10)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 225/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 11:39:23, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
813 packets input, 281166 bytes, 0 no buffer
Received 82 broadcasts (35 multicasts)
1111 input errors, 303 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 35 multicast, 0 pause input
5095 packets output, 1160362 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Transmit GigabitEthernet1/0/16 Receive
0 Bytes 0 Bytes
0 Unicast frames 0 Unicast frames
0 Multicast frames 0 Multicast frames
0 Broadcast frames 0 Broadcast frames
0 Too old frames 0 Unicast bytes
0 Deferred frames 0 Multicast bytes
0 MTU exceeded frames 0 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 0 Minimum size frames
0 8 collision frames 0 65 to 127 byte frames
0 9 collision frames 0 128 to 255 byte frames
0 10 collision frames 0 256 to 511 byte frames
0 11 collision frames 0 512 to 1023 byte frames
0 12 collision frames 0 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
0 64 byte frames 0 Valid frames, too small
0 127 byte frames
0 255 byte frames 0 Too old frames
0 511 byte frames 0 Valid oversize frames
0 1023 byte frames 0 System FCS error frames
0 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
Really hope to fing the issue, last thing I need is a bad port on that switch :(
04-30-2018 04:36 AM
04-30-2018 08:12 AM
04-30-2018 04:47 AM
The amber LED is caused by faulty cabling. Do the following:
1. Command: test cable tdr int Gi1/0/16;
2. Wait for approximately 5 to 7 seconds;
3. Command: sh cable tdr int Gi1/0/16; and
4. Post the complete output to #3.
04-30-2018 05:10 AM
04-30-2018 08:13 AM
04-30-2018 01:32 PM
@rasmus.elmholt wrote:
For inspiration: https://supportforums.cisco.com/t5/network-infrastructure-documents/how-to-use-time-domain-reflectometer-tdr/ta-p/3119327
I wrote that.
The recommendation is to disconnect the end device while measuring as far as I rememeber to avoid spiking the end device.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/15-0_2_se/configuration/guide/scg3750/swtrbl.html?bookSearch=true#38827
That's old school thinking. Not applicable nowadays.
05-01-2018 04:54 AM
04-30-2018 08:10 AM
04-30-2018 10:06 AM
04-30-2018 01:21 PM
Yesterday it does. I have connectivity with the new device connected to port 16, and also connectivity with the cloud key now on port 15. Very strange, that’s why I was leaning on a config issue.
04-30-2018 01:22 PM
04-30-2018 01:33 PM
@idscomm wrote:
I ran that command yesterday and it gave me 1 failure on 1 Pair. I replaced the cable, re-ran the test and came back clean. I can give it a try again to see if it changed ... I even tried with a new crossover cable but I was getting the same behaviour from port #16... I kind of eliminated cable issue after that. What do you think?
I want to see the result to the command "sh test cable tdr int g 1/0/16".
Also post the complete output to the command "sh version".
