03-24-2021 02:10 AM
Hi, everyone!
I wanted to make a static DHCP pool to a device. i tried the binding options but in vain! i assigned the IP dynamically and i found the Id looks like 00aa.aabb.bbcc.cc00 or 00aa.aabb.bbcc.cc00.
Since it is not on the format Mac@ | Client_Id | User_name: What this can be?
Best Regards!
Solved! Go to Solution.
03-24-2021 04:55 AM
Thank you all for your replies!
my issue was not how to configure static pool ! but what is the #DHCP_ID_Type.
After some Show commands, i found a display_problem. the Client_identifier is may be large to display it on a single line!
it's on the format 00aa.aabb.bbcc.cc00.0000 ! and now it'is successfully binded
by the way, this id's format is for iLO5 port on an HP Server!
03-24-2021 02:38 AM
can you post an example config, what is configured?
Look at the config :
03-24-2021 03:42 AM
Hello
DHCP pool static example:
Pc mac address 0011.1111.1111 - ip address 10.1.1.10
ip dhcp pool static_pc
host 10.1.1.10.255.255.255.0
client-identifier 0100.1111.1111.11 ( 01 extention added to mac add of client)
default-router 10.1.1.254
lease 0 8
03-24-2021 03:53 AM - edited 03-24-2021 03:55 AM
what do you mean with " format Mac@ | Client_Id | User_name" ?
you need either mac-address OR client-id to make a static entry the "|" means one of these options (or)
-> this looks like it is the client-id
The following example shows how to create a manual binding for a client named example1.abc.com that sends a client identifier in the DHCP packet. The MAC address of the client is 02c7.f800.0422 and the IP address of the client is 172.16.2.254.
ip dhcp pool pool1 host 172.16.2.254 client-identifier 01b7.0813.8811.66 client-name example1
The following example shows how to create a manual binding for a client named example2.abc.com that does not send a client identifier in the DHCP packet. The MAC address of the client is 02c7.f800.0422 and the IP address of the client is 172.16.2.253.
ip dhcp pool pool2 host 172.16.2.253 hardware-address 02c7.f800.0422 ethernet client-name example1
03-24-2021 04:55 AM
