02-08-2020 05:03 PM - edited 02-08-2020 10:01 PM
02-08-2020 08:39 PM
below command should give you full information of the device : (make sure you understand the and impact, if the busy network, do not run, suggest to run when the load in minimal and maintenance window) - since this collects all the information - CPU may spike for a time being until the command finish product all information.
show diag
show tech
=====️ Preenayamo Vasudevam ️=====
02-08-2020 09:00 PM
Is there any command available similar to "sh diagnostic result module status" or " sh module" in cisco 3845
02-08-2020 09:25 PM
show diag give more information as you look - you can try those commands (no harm of that helps you)
02-08-2020 10:02 PM
